• NOTICE: This "Forum Navigation Questions" forum is only for asking questions related to navigating this web site. DO NOT post car-related questions here., For car-related questions, use the appropriate marque-related forum.
Browser script question
NutmegCT
(moved from Help topic)
Question: until two days ago, if I want to use File Manager, I'd just click it and get the File Manager window.
Now, if I click the link, I still see "Run script "void(0)" under the link, and the focus still changes from the text window to the File Manager link, but nothing else happens. No window opens. The page source shows the full script, but it seems to have no effect.
File Manager and Poll Manager work fine in Firefox and Camino, but not in the browser I've used all year - Safari 3.1.
Any thoughts? I've cleared cache, cleared cookies, and even completely reset Safari. Logged back in, but still no luck.
Thanks.
Tom
Dave Russell
Yoda - R.I.P
I'm in Safari 3.1. Will try attaching a pic.
PS - it worked for me.
NutmegCT
NutmegCT
Thanks Dave.
Say - are you using Safari on a Mac, or on a PC? I didn't have this trouble until (I think) I installed the recommended Security Update 2008-2 on OSX, or the Safari 3.1 update. Naturally, both of these were done in the last couple days.
Really strange that all the browser scripts have been "disabled", but only in Safari.
Tom
Dave Russell
Yoda - R.I.P
Hi Tom,
IMac/Intel system 10.4.11.
I'm presently running Safari 3.1. I have not installed Security update 2008-002.
Now you have me spooked. Maybe I won't do this update? Can you go back to the earlier version & see what happens?
NutmegCT
NutmegCT
Thanks Dave. I've been googling the Safari 3.1 update, and the SecUpd 2008-02. So far no obvious problems are mentioned - but it is interesting that this javascript "issue" occurs on sites other than BCF, but only in my Safari 3.1.
Removing a SecUpd is a total pain, but I'm thinking it's a Safari problem, as 3.1 is supposed (!) to handle javascript more "efficiently and securely". And again, the SecUpd would affect more than Safari.
Sure wish I could find a 3.0.4 install and "backdate" my 3.1. But I haven't found a single "previous versions" anywhere - even on apple.com
Onward through the fog!
Tom
Dave Russell
Yoda - R.I.P
See my revised note above. I have Safari 3.0.4 if it would help. I think the problem might be in the 2008-002 part though.
aero3113 “Not secure” message in web browser Austin Healey 18
C How best to restore red script on valve cover? Austin Healey 7
healeydan Austin-Healey trunk script installation question Austin Healey 15
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
Lin Austin Healey Script on Boot Lid Austin Healey 28
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
