Starting engine after sitting 2 yrs
rficalora
I'll likely be purchasing a B that's been sitting for 2yrs. Owner says the car was running when he parked it (inside a garage, concrete floor, & engine bay appears consistent with that although no way to know for sure). I was able to hand turn the crank (about 1/8 turn; didn't try more than that) with little resistance -- with plugs in it[now that I'm thinking about it I'll probably go back & re-check as I have a nagging feeling there was too little resistance]... anway, if I do buy this car, what would you recommend I do before trying to start it? For sure I'll drain the tank & put fresh gas in & new fuel filter -- maybe even use an external tank to get it running if there's any rust evident.
Carb is a weber -- not sure if there'd be varnish build up that needs to be cleaned before trying to start the car after 2yrs or not?? Advice?
Engine -- I'll clean the plugs & ensure they're properly gapped... will change the oil... how should I treat the cylinders before trying to start it?
Anything else I should be thinking about?
Thanks in advance
Rob
Wow, that was quick... thanks jaybird!
Saw you got a '66 recently... i used to have a '67 -- it was my favorite of the ones I had(i also had a '76 & my dad had a '79)... anyway, have fun putting the '66 back together!
I can't WAIT! In fact, I don't want to wait a week or two for dahubby to go pick it up. I'm toying with going down this weekend. Since dahubby's gone til Monday and works every day (unretired) next week.
Otherwise, I have to shop at moss. And narrow down colors. And pick a name for her.
(check out the rest of Tony's website, particularly the Weimerology! He's the guy I'm --we're-- buying the '66 from)
Jaybird is absolutely right. I thought about Tony's excellent article before I was half way through your post. It was one of the first things I found when I got my B, and printed it out as a checklist. Hopefully I'll get the time to get through it soon! /ubbthreads/images/graemlins/rolleyes.gif
I've printed it out for the Binabox.
[ QUOTE ]
[/ QUOTE ]
There ya go...you got it right, now /ubbthreads/images/graemlins/jester.gif
G Spitfire Starting Spit engine after sitting a few years Triumph 3
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
J Starting rebuilt engine ! Austin Healey 8
Lutz Kramer Problem starting the cold engine Austin Healey 16
J TR2/3/3A Engine starting Triumph 8
R Test Starting Engine Triumph 16
PatGalvin Starting Engine on rolling chassis - a good idea? Triumph 25
D Starting the New Engine Triumph 39
J 30 years of not starting engine,should I try it? Triumph 26
T Difficulty starting engine Triumph 31
vping Starting an Engine parts list - Winter Project MG 6
E hard starting-engine quits Spridgets 14
Bruce_B Just want to make sure before starting engine.... Spridgets 2
R MGB MGB engine starting problems MG 9
D starting the engine w/ key Spridgets 2
M Starting engine Jaguar 1
D Help Jag Mk2 hot engine starting problems Jaguar 4
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
