I'll likely be purchasing a B that's been sitting for 2yrs. Owner says the car was running when he parked it (inside a garage, concrete floor, & engine bay appears consistent with that although no way to know for sure). I was able to hand turn the crank (about 1/8 turn; didn't try more than that) with little resistance -- with plugs in it[now that I'm thinking about it I'll probably go back & re-check as I have a nagging feeling there was too little resistance]... anway, if I do buy this car, what would you recommend I do before trying to start it? For sure I'll drain the tank & put fresh gas in & new fuel filter -- maybe even use an external tank to get it running if there's any rust evident.
Carb is a weber -- not sure if there'd be varnish build up that needs to be cleaned before trying to start the car after 2yrs or not?? Advice?
Engine -- I'll clean the plugs & ensure they're properly gapped... will change the oil... how should I treat the cylinders before trying to start it?
Anything else I should be thinking about?
Thanks in advance
Rob
Thanks in advance
Rob
