starting the engine w/ key
duplaga1952
Member
the engine cranked when we jumped the selanoid w/ a screw driver, so we assumed the selanoid was shot. new sel and still not cranking. any location to trouble shoot 1st or what to look for wiring wise?
thanks bob /ubbthreads/images/graemlins/confused.gif
Biff
Re: starting the engine w/ key
Are you getting power to the solenoid?
When the key is in the start position power should go from that ignition switch contact to the solenoid to activate it. Back trace that wire from the solenoid to the switch.
jlaird
Would not hurt to get out the wireing diagram and the meter and check to see where the power is and where it should be.
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
J Starting rebuilt engine ! Austin Healey 8
Lutz Kramer Problem starting the cold engine Austin Healey 16
J TR2/3/3A Engine starting Triumph 8
R Test Starting Engine Triumph 16
PatGalvin Starting Engine on rolling chassis - a good idea? Triumph 25
D Starting the New Engine Triumph 39
J 30 years of not starting engine,should I try it? Triumph 26
T Difficulty starting engine Triumph 31
vping Starting an Engine parts list - Winter Project MG 6
E hard starting-engine quits Spridgets 14
Bruce_B Just want to make sure before starting engine.... Spridgets 2
R MGB MGB engine starting problems MG 9
G Spitfire Starting Spit engine after sitting a few years Triumph 3
M Starting engine Jaguar 1
R Starting engine after sitting 2 yrs MG 6
D Help Jag Mk2 hot engine starting problems Jaguar 4
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
