30 years of not starting engine,should I try it?
JonnyRotten
after 30 years of not starting engine it turns over easy with front crank.should I try to start or will I damage engine.Is there any prep work I should to first(take out plugs and oil cylinders?)I dont want to do anything stupid that will cost me more later.1960 tr3a.
Safari
Re: 30 years of not starting engine,should I try i
I have started many old engines. I pull plugs and use Marvel Mystery Oil in Cly. Drain all gas and use fresh fuel. I change oil and filters. I will check compression and always have a fire extinguisher on hand. Seals, hose, wires may be dry rotted or dried out. You will have to perform a detailed inspection. The last engine I started had not run in over 10 yeas and I had it going in 45 min. It took another 6 months to fix the hydraulics, clutch and brakes. I have a MGA engine on my bench which hasn't ran in 20 years, it was ok when I took it out, I don't think I will have any issues when I reinstall it. As in all things your mileage may very and I am sure many others here will have some strong opinions.
Mickey Richaud
Jonny -
STOP!
Before you do anything, check here
This is MGB-specific, but Moderator Tony has a great checklist for waking "sleeping" cars that applies to all.
bgbassplyr
LINK NOT WORKING.
SkinnedKnuckles
I'd say NO! I know how tempting it is, but not time yet. You'd have to pour gas down the carbs at this point, and If by a miracle you did get it running, then you'd want to go around the block. Then to the store. Then you'd have to push it back to your house. And yes, something could be damaged by trying the engine at this point.
If it were me I'd start on the brakes. That's the most important system on your vehicle. Lots there to replace & rebuild = anything rubbber. Same with the clutch. Then's the time to decide whether to go back with silicone or LMA fluid (another can-o-worms?). While you're waiting on parts you can change the engine & trans oil. Maybe drop the oil pan and clean out the gunk in the bottom beforehand.
You need to drain any "gas" in the tank. Consider pulling the tank. There is likely lead residue (crud) in there that you don't want in the system. I fixed up mine with the POR-15 cleaner/liner kit. All the rubber in that system needs to be replaced, too.
There is alot of cleaning to do before you try and start it. Take the time and get it ready so that when it starts it will keep running. You'll get much more satisfaction that way.
SkinnedKnuckles
A question, Mr. Rotten. Did you get any indication why it was parked in 1980? If not - call back once the check clears and ask again. There may have been time to recollect... That info could really help you out. And what's the mileage?
J
JonnyRotten
The guy i bought it from Is my fathers friend for 50 years. I trust every word he says.he said he garaged it for money issues(insurance)and planned to restore it over time.He drove it into garage and its sat ever since.He also has new seat covers,tonue cover, exhaust,carpet,and soft top new still in box.
Don_R
Jonny,
This deal just keeps getting better....You have a true survivor car there.
I have my dads 59 TR 3 and it is far from the condition of your car. You got yourself a nice car there at a really good price IMHO.
T
TRDejaVu
I had already checked the frame for rust and damage. I completely re-did the brake hydraulics. Checked all the suspension mounting points for cracks and other damage as well as general suspension condition. Checked the steering for wear as well as smooth operation. Replaced all the flexible fuel hoses, checked the fuel system and tank for crud. Drained and flushed the cooling system and because it was summer just refilled with water for temporary testing purposes. Replaced the radiator hoses. Dropped the sump to see if any metal chunks were present. Also checked the oil pump inlet screen for sludge. Changed the oil and filter. Positioned a fire extinguisher close by and connected a fully charged batter. Checked each electrical circuit, lights, ignition, wipers, heater fan etc to look for spark sounds or smoke. Disconnected the ignition, turned the engine over on the starter to check for reasonable oil pressure and obvious leaks.
Walked away from it and mentally checked if I had forgotten anything. Then I fired it up.
TR3driver
Great Pumpkin - R.I.P
I'm from a different school than Tony. TS13571L was "put away wet" some 30 years before it came to me; and for it's first firing I just pulled the plugs, squirted each hole with a healthy dose of WD40, and then spun it with the starter until the oil pressure came up (with the plugs still out). Put the plugs back in, and set about making it run.
Dumped a gallon of gas in the tank, discovered fuel shut off valve was clogged and original pump didn't pump. So I temporarily bypassed both of them with a little Facet electric pump (part of my on-board spares kit).
No fire at the plugs, apparently the antique points were dirty, so I threw a new set of points in (again from the on-board spares kit, from TS39781LO). That & some carb cleaner down the carb throats (which also doubles as starting fluid) got it to fire and run for just a few seconds; long enough to indicate to me that the engine was basically healthy (no bad noises, no excess smoke from exhaust, etc.) Only then did I change oil, add coolant, adjust the valves (actually swapped in the recently reconditioned rocker shaft from the TR3A) etc.
My thinking was that I didn't want to put a lot of work into an engine that I might have to tear down anyway. This brief procedure (about an hour total) was enough to give me a list of what I wanted to do, which fortunately did not include pulling the engine.
But it kind of depends on your intentions. My goal (as usual) was a running, functional car as quickly as possible, rather than a complete restoration. As it happened, it worked out great for me. It's covered perhaps 2000 miles since then, and the only engine problems have been the screw for the condenser working loose; and the ignition coil failed during VTR/TRfest. Fortunately, TRF had some for sale at the event, so I was back on the road quickly.
GaryBeu
Banned
I'm really glad to find someone who goes to the same school I do! I did basically the same thing with my MGB...couldn't see putting megabucks into everything if the engine and trans were crap. It's worked out well so far.
J
JonnyRotten
Ive read all your posts and planned on doing those things.my question is will starting engine do internal damage.as in cylinder walls, crank, bearings,things like that if rust has formed inside of engine.
Andrew Mace
Probably not, IF....
Suggestions above to lightly oil the cylinders with Marvel Mystery Oil or even regular motor oil are good ones. Key, IMO, is to spin the engine with the ignition disables until you get good oil pressure reading on the gauge (or can verify in some other way). It might even be worth having the valve cover off while you're spinning the engine to build pressure; that way you can see if the valve train is getting any lubrication.
There's always the reasonable chance that rings are stuck in the piston lands, even though the engine is spinning over well, and that there is some minor surface rust on the cylinder walls. More than likely, either or both problems would work themselves out quickly once the engine has run a bit and gotten some fresh oil, etc.
TR3driver
While it is possible, those are the exact things you are going to renew anyway, if it becomes necessary to tear the engine down. IOW, trying to start the engine may turn existing damage into more severe damage; but you were going to replace the damaged components anyway so it really doesn't matter.
And since it turns easily, chances are very good that there is no corrosion anyway.
Safari
In some ways it is a no guts no glory issue. I have never had the least bit of a problem trying to start an old engine but that is my mind set. I would definitely pull the valve cover off and oil the valve train and make sure it is functioning as designed. Some of the attitude to doing this also has a lot to do with your experience and background.
I also don't start an engine and try to drive the car on the road, I evaluate the brakes, clutch, electrical, and every system before I try to go on the road. My TR6 had not ran for 10 years starting the engine was easy, replacing the clutch, rebuilding the brakes and suspension were the hard work. Knowing I had a good engine made the other chores a lot easier.
Deleted member 8987
Pull the plugs.
Oil the cylinders WELL, MMO is good.
CHANGE the oil and filter (after 30 years of condensation, get it right).
CRANK it with NO PLUGS, and therefore NO COMPRESSION putting any force on rod bearings until you get full cranking oil pressure (filter full, oil passages full, all journals lubed).
I would do it with the rocker cover off, and see if you get oil to the proper places whilst cranking.
If you put new fuel in it, blew out the lines, you should also now have fresh fuel at the carbs.
Check for spark now, making certain the points ain't corroded.
Install new plugs (no telling what condition the old ones are in) and try to start it.
You have oiled it well, no dry spots, full pressure, and it's the best you can do.
Done a whole lot of old motors that way, and was always surprised at how well they ran when done.
Dave
poolboy
And you don't have to put gas in the tank. If there is anything swimming around in it, it may cause you to go on a wild goose chase looking for a reason that the engine won't run.
I have an engine, as Safari knows, that runs off a 1 gallon gas can and an outboard motor priming bulb to get gas to the fuel pump.
tdskip
Two questions Ken;
1) does the person running next to the car get tired easily?
2) how fast can you drive before your lose your runner?
:whistle:
G Spitfire Starting Spit engine after sitting a few years Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR4/4A Starting TR4A after 30 years Triumph 12
B MGA Starting up the MGA after 20 years [applies to other MGs too] MG 3
H Advice asked not starting after 2 years Austin Healey 6
TexasSprite Starting a Sprite after 16 years in storage Spridgets 3
HAN8L1965 Starting a 1098 after 33 years Spridgets 9
Nelson 62 years and holding Spridgets 3
S 10 Years Spridgets 3
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
D MGB 1975 MGB 20 Years Resurrection MG 1
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
tr6nitjulius TR6 Celebrating 43 years Triumph 2
JPSmit 60 years - Mg Midget Spridgets 0
jlaird MGB Don't post like I did 10 years ago. MG 7
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
S 50 years ago this week... Spridgets 7
M 2018 News Years resolution Spridgets 2
S Five Years Ago Today... Spridgets 7
Rob Glasgow A few Years in Between Austin Healey 20
B GT6 I'm back after 8-10 years !! Triumph 1
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
V TR4/4A Learned to drive in my father's 1958 TR3 58 years ago, never got over it Triumph 3
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
CLEAH My Healey Story, 40 Years On Austin Healey 13
D Lilly first time running in 15 years.... Austin Healey 19
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
3798j Off Topic Fifty Years Ago, Me & My TR3 Triumph 17
drooartz MGB Same car, same spot, 6 years apart MG 12
E TR4/4A TR4 Start up after 35 Years Triumph 1
CessnaTPA USA Import Years? British Motor Corp 2
simon1966 32 years on! Austin Healey 4
S Has it really been 3 years? Spridgets 2
a40bob Seven years later Other British Cars 13
drooartz MGB First drive in 3 years! MG 15
T Impressions: First drive [short] in years Spridgets 7
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
3798j 50 years ago Today Other Cars 1
Zitch Off Topic Will there be a market for these old British Cars in 15-20 years? Triumph 18
G Common Years for Austin-Healey 3000 frames Austin Healey 5
tomshobby After more than 10 years it is back on the road. Spridgets 10
H First ride in 28 years Austin Healey 5
jlaird Thought I would share 50 years with a BE Spridgets 14
Z MGB My First MGB in 41 Years MG 9
aeronca65t 44 years apart Spridgets 3
richberman 2.5 years later... Austin Healey 30
B getting closer...only took about 8 years! Spridgets 4
Jim_Gruber Bugsy II sees the light of day - First Time in 28 years Spridgets 25
