Advice asked not starting after 2 years
hama61
Hello,
Today after a period of almost 2 years not using the Healey. I installed a new battery and much to my surprise and disappontment the car didn't come to life. Before she always started after the ticking of the fuel pump stopped with one push on the button.
The fuelpump does currently not tic at all and did I notice as well, that some of the electrics doesn't work either. The left turn works the right turn however each time only once but assume more will follow after such a long time of not using.
Harry
Just because the battery is new does not mean it is good. Could be low on fluids or not properly charged.
I don't know what the climate is like where you are, but the contact points (inside the distributor) could have a layer of oxidation on them, preventing the magnetic field collapse that allows the coil to create the spark.
Prior to starting, I would go through all the procedures that a normal tune-up would include, even if just refurbishing the plugs and points. A little dribble of oil (up to an once) down each cylinder wouldn't hurt, and you could rotate the engine by hand to distribute it (if you hit the starter button with the plugs out, make sure you put rags over the openings, or there'll be oil everywhere).
I'd give the fuel pump a couple good raps with a mallet, and see if that doen's bring it back to life. It too make need a tune up, cleaning its contact points.
I would expect that whatever gas was in the tank has lost most of its charge too, so best results of attempting to start the engine would be acheived with some fresh gasoline.
My first suggestion to to check your grounds. If they are not tight, all kinds of strange things can happen. The most difficult ground strap to check is the engine to chassis ground on the right lower side of the rear engine plate. It is about 6 inches long. Sometimes these straps get oil soaked and can loosen.
I like Randy's suggestion regarding the fuel. After two years, if it has ethanol in it, it's bad. Drain the carbs and clean them... All the other advice is good, too and you should check everything methodically.
Hi Harry,
Having spent some time in the Netherlands, I am aware of the high humidity your Healey has experienced and can expect that all your electrical problems are being caused by the corrosion formed within your electrical system. First, I would clean and set the points in both your distributor and fuel pump as the tungsten points have a tendency to form oxidation during periods of inactivity. Second, I would go through all your bullet connectors, especially where the unit that are not working, and clean and apply dielectric grease (or Vaseline) before reconnecting to keep out the moisture.
I also agree with the group that cleaning the fuel system is a must to eliminate clogs by contaminates left behind after evaporation. Although I am not sure of the makeup of the fuel you are using, I would expect it contains additives or even alcohol that can absorb moisture that will be left behind after the more volatile components of your gasoline evaporate and will do damage.
One last point, I would also consider flushing the brake system as the standard types of fluids will absorb moisture and cause problems.
All the best,
Ray (64BJ8P1)
@ Randy I think best to be compared to Pennsylvania this weekend i will do the tune up and check the contact points.
@ Boyracer thanks for the advice will check
@ Steve the gasoline ron 95 contains 2 per cent ethanol it is allowed to blend up to 5 per cent.
@ Rac 68 except the tune up will check the bulletconnectors as well
Gasoline normally a blend of 5-6 light nafta like fractions (pygas - isomerate -raffinate - light virgin nafta as well small percentage of Mtbe i believe this isn't allowed in the US anymore contains as well ETBE and aromatics like xylene and Toluene 1 % benzene is allowed as well.
I regret already, that i didn't start a run the Healey once in a while
Harry
H Advice asked for restoration two seater hardtops Austin Healey 7
H Tow advice asked Austin Healey 10
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
S TR6 new TR6 owner looking for advice Triumph 9
R Factory Hardtop Restoration Advice Spridgets 2
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Simmo TR6 CARPETS advice pleaese Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Tool Advice Sought Austin Healey 3
C Advice for installing a 3000 Grille??? Austin Healey 7
R Remove engine/transmission advice needed Austin Healey 4
