HAN8L1965
Need Help,
Did not rebuild my 65 1098, but replaced gaskets, oil, filters, rebuilt carbs, points ,condenser, terminal,new plugs. Turns over easily. seems to have compression will be doing an actual compression test tomorrow. Spark is there, the engine fires but will not continue. The engine is out of the car and we are using a large squeeze bottle for fuel. Is a certain amount of fuel pressure necessary?
Any suggestions, is there a starting point for carbs, also will be checking the timing. I have been told it ran when it was put away.
Mark
Mark
