MGA Starting up the MGA after 20 years [applies to other MGs too]
Bossbill
While talking to a guy at work about the MGB font suspension I need to get from him for the MGA, the conversation turned to how the MG was doing.
The MGA sat in a storage garage for a decade or so and has now sat in the carport for another 10. It needs a full restoration, but is complete. The left front spindle sits in the trunk with a stripped out swivel pin thread. The MGB disc brake suspension will go in.
I don't know how we got around to the topic, but he asked how it ran. I have no idea since I never tried to start it. And then the wheels started turning. I should get it running! There's at least 3 project cars ahead of it in the restoration order plus a race car to feed, but this sounded interesting.
The oil was full but rather black. An oil and filter change was in order. But need I bother? I grabbed the fan, gave it a twist and the crank turned. Ok, we can move forward. While the oil was draining the plugs came out. Hey, that distributor has no vacuum advance. It's got dual points! Huh. The DCOE weber is there and it looks impossible to squirt gas into the throat. But I digress.
Squirt some Marvel Mystery oil into the cylinders and get back to the oil. Yuck...very black. Let it drain for an hour or so.
Then onto the filter.
The oil filter adapter dropped down and since I had 3 O rings, one must be for the block. I removed the adapter. Judging by the shape of the other O ring, this would be hard as kryptonite too. And it was.
At first I thought I was poking my awl into the block. But the black thing up there had a slight amount of give. But the point of the very sharp awl would not penetrate the ring. Hammer on the awl -- nope.
I went back into the house to check the mg guru site and yep. There is indeed an O ring up there. And they get hard. Is this O-ring 50 years old? Might be.
I then got out the dremel and put a straight rod into the end. I figured at the speed the dremel turns it would friction burn itself into the O ring. And the rod would not damage the block. I finally got a few holes in the O ring and went back into the shop to build a pry tool. I sourced a 1/4" rod and bent the end into the shape of a claw hammer. I ground the width so that it would go into the groove of the block and gave the claw end a sharp tip. A few taps, a little wedge action and out came -- 1/3 of the seal. The rest came out fairly easy. In went fresh oil and filter.
The next day I decided to spin the engine with the starter.
But MGAs use mechanical starter relays and I wasn't going to mess about trying to pull on the rod while testing other things.
Went back into the shop and sourced a Ford starter solenoid. Moved the starter lead to the electric solenoid, hooked up a battery pack to the solenoid and ground, ran a ground to the solenoid and a remote starter button to the solenoid. Hit the button and engine turned over just as if I had run it last week. OK, the plugs were out, but this thing sounded real good for having sat this long.
Next week I'll hot wire the coil and rig up an electrical fuel pump from a gas can. I'm not messing around with an old fuel tank or a Lucas fuel pump ...
Bill
Mickey Richaud
We're havin' fun now!
:cheers:
Mickey
D MGA MGA hard starting sometime backfires MG 2
M Sanity check - starting project on MGA Restoration & Tools 6
D MGA Difficult Starting MGA 1500 MG 6
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
