GT6 I'm back after 8-10 years !!
Bob Buxbaum
The TR8 is long gone to a happy owner. But the 1970 GT6 remains. It has been torn apart after a paint bubble turned into an archaeological dig, and a shell laying on a roll around wood table I built for the work. I started to remove more and more bondo, cutting out rusted panels, and found stainless steel plates laid down on top of the rusted front floor boards. I started working on putting it back together but was overwhelmed by the mess. So, why becoming fully engaged in my local SCCA Region's Solo program, the GT6 was rolled into a corner of my shop. About 8 years ago someone brought me a 1987 BMW 325i ------ and withing 5-6 months the word got out that I could handle just about anything on E30s and 36s (not quite, but I was learning fast), worked cheap (ish), and the work was good. And the GT6 sat. And sat, and sat. But, approaching the ripe old age of 69, I started to tapered off other's Bimmers, and tended to my growing fleet of the of my own. Don't tell anybody I said this, but they can be (almost) as troublesome as British cars, but they tend to STAY fixed longer. Anyway -----------
My shop floor sadly is not as flat as I wanted when it was poured. So, I bought vertically adjustable caster, installed them where the now flat spotted lighter casters were, cleared space on the shop floor, and rolled out the GT6. I had done a good bit of rust repairs on other folk's 30s and 36s, so I was far more prepared to got at the 6 again. I soon found out how many mistakes I had already committed a decade ago. The first thing I realized was that the braces I welded in to stabilize the body while it was on the "twirler" I had built had moved the left A pillar area below the windshield. As I was starting to hang panels repairing to treat the less than rust free sheet metal and then start welding, stuff just did not fit. Using tape measures as well as the electronic gauge from my camber tool, I found out how out of wack that area was. The bracing was removed from the front of the left door opening and after pulling and pushing on the body just aft of the firewall, I had the vertical measurements and the spacing from the right side door opening corrected.
Since it is hot as **** in the midwest, and the shop only has some fans, I am good for about 3 hours or so, and then back into the house. So, as things go along I will post things, and people can opine as to what I am doing wrong !! The WORST thing I did was soda blast the outer body and frame not knowing that it had to be neutralized. CRAP !!!!!!!! The inner structure were not, as the sheet metal was intact when I blasted the body and frame. The body will be hand sanded protected before painting. The inner structures will be cleaned and covered in POR 15 using there full range of treatments and then sponge sponge on the black stuff. So .... this brings me to my first questions, but that will be another post.
Nelson 62 years and holding Spridgets 3
S 10 Years Spridgets 3
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
D MGB 1975 MGB 20 Years Resurrection MG 1
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
tr6nitjulius TR6 Celebrating 43 years Triumph 2
JPSmit 60 years - Mg Midget Spridgets 0
jlaird MGB Don't post like I did 10 years ago. MG 7
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
S 50 years ago this week... Spridgets 7
M 2018 News Years resolution Spridgets 2
S Five Years Ago Today... Spridgets 7
Rob Glasgow A few Years in Between Austin Healey 20
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
V TR4/4A Learned to drive in my father's 1958 TR3 58 years ago, never got over it Triumph 3
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
CLEAH My Healey Story, 40 Years On Austin Healey 13
D Lilly first time running in 15 years.... Austin Healey 19
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
3798j Off Topic Fifty Years Ago, Me & My TR3 Triumph 17
drooartz MGB Same car, same spot, 6 years apart MG 12
E TR4/4A TR4 Start up after 35 Years Triumph 1
CessnaTPA USA Import Years? British Motor Corp 2
R TR4/4A Starting TR4A after 30 years Triumph 12
simon1966 32 years on! Austin Healey 4
S Has it really been 3 years? Spridgets 2
a40bob Seven years later Other British Cars 13
drooartz MGB First drive in 3 years! MG 15
T Impressions: First drive [short] in years Spridgets 7
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
3798j 50 years ago Today Other Cars 1
Zitch Off Topic Will there be a market for these old British Cars in 15-20 years? Triumph 18
G Common Years for Austin-Healey 3000 frames Austin Healey 5
tomshobby After more than 10 years it is back on the road. Spridgets 10
H First ride in 28 years Austin Healey 5
jlaird Thought I would share 50 years with a BE Spridgets 14
Z MGB My First MGB in 41 Years MG 9
aeronca65t 44 years apart Spridgets 3
richberman 2.5 years later... Austin Healey 30
B MGA Starting up the MGA after 20 years [applies to other MGs too] MG 3
B getting closer...only took about 8 years! Spridgets 4
Jim_Gruber Bugsy II sees the light of day - First Time in 28 years Spridgets 25
drooartz Two years ago today MG 6
AngliaGT Can't Believe that it's Been Three Years..... MG 3
PAUL161 MGB MGB vin numbers verses years. MG 6
B Clutch pedal no fluid? 2 -3 years of sitting... Spridgets 30
Boink Man recovers stolen Healey after 42 years! Austin Healey 36
