getting closer...only took about 8 years!
Blackjokr
so here;s what I have done since last post: new antenna, new antenna cable, new speaker (thanks JPSMit for the ebay link!), consolre put back into place, cigarette lighter working, light in cigarette lighter working, ignition cylinder and housing replaced on steering whell, removed crappy old box speakers from back seat, glued down some loose carpeting, put convertibale top frame back on, repaired a few snaps (need to replace those other thigns that have the nipple on them for the top to connect), found horn issue (looking to get new horns), resolved last marker ligth issue, resolved rear tail and marker light issues, fixed license plate older (dummy painter put it in wrong holes and handle was smacking it!), got trunk light working properly, map light worksm radio works, cleaned out a whole lotta dirt! vacuumed my poor midget, and some tasty other items. Love doing this..this car was my hated car, but now I am LOVING it and cant wait to get to the show with it!
Lou :encouragement:
JPSmit
woo hoo! (of course at some point we need pics)
Jim_Gruber
Bugsy II better not take me that long to finish. Gerard receives my Dual Master today for resleeving and conversion to 3/4" in Brass, Wishbones arrived at Apple Hydraulics to be rebushed on Wednesday, ship be back next Wednesday, box of seals, springs, for pedal box from VB came yesterday along with MOSS Brake, Clutch, and Suspension Sale Flyer. Time to order brake hoses, rotors, rear wheel cylinders for conversion to Disk Brakes, and Major Suspension Kit to go with the refurbished Wishbones. Sale comes at the right time as I am concentrating on those sub assemblies right now. Being able to stop and turn are always a major concern. Now to figure out $ in the Budget for a set of Peter C's best shocks and get the 5 Speed Adapter Kit on order from Gerard. Body work starts in earnest in next 10 days. My angle grinder and flapper wheel is anxious to get started. Vacation this weekend, M & T at the cottage. Got a new garage door installed on Wednesday, Hardtop went down to get stored in the rafters so it is out of the way and won't get damaged in my single car garage at home. Progress ever onward.
B
Blackjokr
I like their summer sales too. Whenever i call I always ask when the next sale is. usually they give me the heads up so I can order when the discounts come in! I just got the insurance card for "The Midge". I am so excited to put it back on the road!
Celtic 77 MGB Getting closer! MG 5
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
Jim_Gruber Spring is getting closer - What Spridget Winter projects do you still need to finish Spridgets 13
R Getting Much Closer Triumph 73
T Getting closer on the inner fender Triumph 3
regularman Getting much closer Spridgets 2
jlaird Progress, getting closer Spridgets 6
billspohn MGA MGA V6 Getting Closer to End MG 2
R IRS Getting closer to assembly Jaguar 1
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
