You'll need the wire from the distributor to the coil, plus power to the coil, and to the starter. For an initial test, you can ignore the generator. The stock starter solenoid has a pushbutton on the back of it, so you can just hook up the big cables to it and not worry about the side wire (or the starter button on the dash).
