TR2/3/3A Engine starting
john283
I've got my engine mounted to the frame and turned it over to get the oil pressure going, but I'm not sure how to hook the electrical up to get it started. Any helpful hints?
You'll need the wire from the distributor to the coil, plus power to the coil, and to the starter. For an initial test, you can ignore the generator. The stock starter solenoid has a pushbutton on the back of it, so you can just hook up the big cables to it and not worry about the side wire (or the starter button on the dash).
When I first tried to start my TR2 back in 2002 the only functioning guage I had was the oil pressure guage. I was hugely disappointed that it refused to start until I learned that the ammeter guage needed to be hooked up (or the brown and brown / white wires tied together) to complete the electrical circuit. 35,000 miles later all is well!
Lou Metelko
Auburn, Indiana
54 TR2LD
That would come under the heading of "power to the coil". A hot wire from the coil to the battery will work just as well.
Been a few years ago, but I've even been known to start the engine with it just sitting on the floor. 3 battery cables, a hot wire, and away we went. Didn't run it for long, though, with no coolant and no exhaust. Danged loud anyway :D
When I took mine in for paint I drove there with just the one wire: battery to coil. Had to cross all of Tucson so I did it at 5 am with my wife following me (no brake lights etc).
Note: Do not attempt.
I hooked up the battery to solenoid and ground, installed a cheap ignition switch and starter button, powered the coil and wired the alternator. She fired right up. Don't forget to plumb your oil pressure gauge. I just provided fuel from a Jerry can.
Probably ran her for 30 minutes, using a house fan to cool the radiator (no fan on my crankshaft). Was a good day.
Pat
https://youtu.be/gp4PZxAnn5o
Sweet Sounding Pat!
Tinman, I am finishing up TS34909 very soon. That's a close number to yours.
If you ever get down Wildomar (...Temecula) way, please stop in!
Thom
Grey Ghost
1959 TR3
TS34909L (now O)
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
J Starting rebuilt engine ! Austin Healey 8
Lutz Kramer Problem starting the cold engine Austin Healey 16
R Test Starting Engine Triumph 16
PatGalvin Starting Engine on rolling chassis - a good idea? Triumph 25
D Starting the New Engine Triumph 39
J 30 years of not starting engine,should I try it? Triumph 26
T Difficulty starting engine Triumph 31
vping Starting an Engine parts list - Winter Project MG 6
E hard starting-engine quits Spridgets 14
Bruce_B Just want to make sure before starting engine.... Spridgets 2
R MGB MGB engine starting problems MG 9
G Spitfire Starting Spit engine after sitting a few years Triumph 3
D starting the engine w/ key Spridgets 2
M Starting engine Jaguar 1
R Starting engine after sitting 2 yrs MG 6
D Help Jag Mk2 hot engine starting problems Jaguar 4
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
R TR2/3/3A Engine revs up and down Triumph 7
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 22
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
