removing steering wheel...method?
Healey_Z
I've checked the service manual, tried to search this forum but I cannot find the answer.
On my punch list is to either refinish/recover or replace the steering wheel. Is there an easy way to get my type of wheel off?
Easy way? The short answer is no.
First, you have to remove the trafficator (turn-signal switch) and stator tube. The stator tube is two (2) pieces on cars (like yours) with an adjustable steering column, so you *may* get by with leaving the lower half in place. The downside is it will be more difficult to get the two (2) tubes put back together__AND THEY ONLY GO ONE (1) WAY__they are slit/indexed to prevent the upper portion from rotating in the lower portion. Many that I've seen have been damaged where they fit together.
Once you've removed the trafficator and wiring (suggest leaving a *pull wire* in the tube, attached to the wires as you pull them out). The aftermarket hub should have a couple of bolts securing it to the splined column There should be a circlip to remove from the splined column, that kept the wheel from sliding too far during normal adjustment range.
Are you sure that you don't want to just polish it up a bit while it's still on the car...?
Alternatively, you could just remove the screws/nuts holding the wheel to the Moto Lita hub, and see if that gets enough access for you.
bighealeysource
Bronze
Like Randy says above, just remove the screws holding the wheel to the mounting hub. The wheel is independent of the mounting hub and allows you to adjust for centering it or simply removing to clean up or polish it. Very simple task and will not require fooling with the trafficator assembly at all. Of course this is all predicated on using a Mota Lita style new wheel or your current one. Unless you are going back to an original Healey wheel most all of the replacements use the hub with detachable wheel.
Regards,
Mike
H
Healey_Z
Oh my. It does look from the picture that I can simply unbolt the wheel and remove it, but I swear I thought the opening in the wheel was smaller than the trafficator assembly. That would be wonderful, may have to leave work early to check it out!
H
Healey_Z
Wow, 9 screws and the thing is off. I feel like a dolt, but frankly I'm ok with it, since I got my wheel off in ten minutes!
The anodized surface is worn uneven and the leather is splotchy and worn through in some places. It is a nice Moto-Lita wheel and I'm thinking of bringing it to the local upholstery place and see if they would rewrap it. If they will, I will polish the spokes and have a nice piece that has some history with the car. That or just go buy an nice wood one :smile:
H
Healey_Z
I visited my upholstery guy. He works on some high end cars. He said stitching it by hand to get it tight and even would be very difficult and he couldn't do the wheel justice. He told me that I would never be happy with it, besides he said, that car should have a wood wheel...which is probably what I will pursue.
I know a guy that will rewrap the leather for you, if you want to go that route. He's done several wheels for BMW ///M Rdstr/Coupe forum members, and they're a picky lot! I even had him wrap my (originally dipped in plastic for a rim)go-kart steering wheel in leather; easily a 9.5 on a 10 scale. He had to build up an area where there was no (dipped) plastic (weld repairs) and it looks very period authentic.
H
Healey_Z
Hey Rick,
His steering wheels look like art pieces. Very nice. Thanks Randy, I think I have decided to go with the wood. Having been active in the cobra replica crowd for ten years, I have a good connection for a nice wheel and will probably go that route.
D Removing the steering wheel hub Spridgets 12
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
Mark_Gibson TR2/3/3A Tips on Removing TR2 Steering Wheel/Head Unit Triumph 14
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
GTP1960 TR2/3/3A Removing the silentbloc rubber pieces. From the steering linkage bush Triumph 7
6 Problem Removing Steering Idler BJ8 Austin Healey 9
drooartz Removing steering column Spridgets 3
drooartz Any gotchas when removing steering rack? Spridgets 5
Monark192 Removing Tie Rod End From Steering Arm Spridgets 11
J Removing the steering column. Austin Healey 10
philman removing nut for steering rack pinion gear Restoration & Tools 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
