Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II
Jim_Gruber
A couple of questions on Bugsy II. I removed Steering column, Steering Wheel, and Steering Rack from Bugsy II. I went to remove the Rack Mounts to the frame and discovered that the PS of my LHD Bugeye has a spacer that fits behind the rack mount. A plate about 1/16" thick. The DS Rack Mounting Plate did not have any such spacer. Is this supposed to be there or some creative attempt with frame alignment that was done by a P.O.? Ideas guys. A flat plate with two drilled holes, rounded corners that if I had not taken these brackets off it would be unseen. Thoughts gentlemen?
One more Shock mount bolt to remove on the DS. The front bolt right by the pivot arm. My HF Electric Impact Gun hammered away on it for a few minutes to no avail. don't want to break out the IR 600 Foot Pound Impact Wrench unless I have to as I don't want to chance breaking the shock mount bolt. Two other two bolts spun loose. Other than PB Blaster liberally administered already, thoughts on getting this bad boy removed.
1) retightening the other two bolts to make sure the shock in not cockeyed after removing the other two bolts.
2) more PB Blaster
3) Heat, makes me nervous as I don't want to melt something internal on the shock.
4) Fire up the Heavy Duty Impact Wrench.
Thoughts gentlemen?
Other than removing LF Shock and RR Shock, Bugsy is ready to go on the Rotisserie. There is nothing left that can be removed from the chassis.
BlueMax
On a LH drive car, the shim should be between front of steering rack support and mount on the RH side!
Break it off, remove the shock and weld a nut onto the remaining bolt.
lewmac
Apply heat to the shock mount from underneath and then rattle gun on the bolt. It likely the shocks will need refurb anyway which is easier than stuffing up the shock mount point. Alternative is to let it snap, grind it flat, center punch and drill, followed by retap. Risky if it snaps below shock mount surface though ....
good luck.
Lew
Jim_Gruber
Jim_Gruber
Come to think of it where things will be rusted up will be from underneath. Tine to get the torch out tomorrow.
Jim_Gruber
Jim_Gruber
No need for the torch. Put the two shock bolts back in and tightened them down and then tried the stubborn bolt. After about three tries with the electric impact wrench it spun out along with the other two. Only thing left to pull is RR shock. Too much yard work today not enough Bugsy time. Just glad for warmer temps finally.
Billm
That shim/spacer should be there on all cars- it always goes on the side opposite of the steering column
Congrats on getting that bolt out
BillM
Jim_Gruber
Jim_Gruber
Good to know. Spacer was a surprise. I think putting other two bolts back in was the key to getting last bolt out. Now to extract one more shock in the rear plus bottom bracket for spring mounting plate. Once that is done need to get engine stands assembled and think about getting it on the rotisserie. Thinking chain hoist in the rear with a rope to each side of the board mounted across turn signal lights. Will run a rope to each side and lift from center to balance. If front will borrow engine crane from neighbor. Same arrangement lift in the center with rope going to each side of frame horns. Hmmm might not be room to get a crane in there plus engine stand. Could be brute force with 4 guys to lift up the front. One way or another I will plan it out. I have a nice I beam in the back of the garage to use as a leverage point. Garage ceiling is low just over 7.5 feet.
Rut's idea of just get it up on sawhorses may be what I need to do.
Jim_Gruber
Jim_Gruber
Will be adding 6" wheels to bottom of engine stands with big U Bolts and tying the bases together to make things more stable so I can roll outside for pressure washing and painting underside.
TulsaFred
Post some pics of your contraption when you get it done, I'd like to see it.
Jim_Gruber
Jim_Gruber
Will do.
fmichaels
I have been away from the forum for a while and happened back tonight since I am looking to get my sprite project back in action and happened to read this thread. I always wondered why there was one shim on the rack and now I know (and I know where it goes). Thanks!
B Now a steering rack question Spridgets 4
matmire New steering rack question... Spridgets 3
N Spitfire Question on solid steering rack mounts! Triumph 3
JPSmit Vauxhall Steering Rack Question Other British Cars 1
C Steering rack Question Triumph 8
mrsprite Steering rack mount question Spridgets 12
PatGalvin Steering Rack install question Triumph 7
T QUestion regards lubricating steering rack Spridgets 9
KVH Steering Rack Question Triumph 3
tony barnhill Steering Rack Question Spridgets 6
S Steering rack replacement lubrication question Spridgets 15
cdsmith Question about steering rack boots. Spridgets 13
77_MG_Midget Rack & Pinion Steering question, 1500 midget Spridgets 2
SCguy TR6 TR4/TR6 Steering rack question Triumph 9
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
PAUL161 T-Series TF Steering Rack MG 0
E TR6 Strange Steering Rack Cap Triumph 3
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
Simmo TR2/3/3A Steering with Escort rack Triumph 5
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
M TR6 Power Steering Rack & Pinion. Triumph 3
C Steering Rack Spridgets 17
M TR6 Replacement Steering Rack ? Triumph 7
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
B TR4/4A Steering rack clearance Triumph 21
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
W Advice please on 1930's? steering wheel and rack Other British Cars 3
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
Rut TR6 Steering rack disassembly Triumph 2
T Steering Rack Lubrication Spridgets 3
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Feathers SP250 steering rack Other British Cars 18
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
T Lubricating the steering rack on a Bug-Eye Spridgets 12
Keith_M steering rack inner ball joint Spridgets 14
Michael Oritt Spitfire Steering rack dimension needed Triumph 1
W What is the purpose of the brown wire on this steering rack? Spridgets 19
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
doughairfield TR4/4A Steering rack placement Triumph 2
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
P TR6 Steering Rack TR6 Triumph 2
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
texbears3 TR4/4A Fan Ext rubbing Steering Rack Triumph 7
RickB 78 Midget steering rack lube? Spridgets 4
P Steering rack adjustment??? Spridgets 6
M Steering rack boot clamps Spridgets 14
