big6, the wiring on the OP switch that you referred to as being for "fuel tank vent". is actually for the Anti Run-on Valve. The wire (WP) in that circuit from the OP switch is the ground (-) until the OP drops, but the positive (+) (NR) for that circuit comes from the ignition switch and is hot only when the key is in the "OFF" position.
If you have the ZS carbs, and your engine does not have excessive blow-by due to worn piston rings or the like, there really is enough vacuum in the carbs' evacuation nipples as designed to handle the crankcase pressure.
Too much plumbing may lead to a build up of emulsification inside the hoses and reduce the efficiency and eventually a build up of unrelieved crankcase pressure.
Because of that I went from this:
To this:
