DavidThorn
Hi All.
My car is a late BJ 8. It is running fine, drives well and returns good fuel consumption. However it would be true to say the engine is a little tired, it does not have particularly good oil pressure and clearly their is some (not excessive) blow past on the pistons which shows itself as an oily haze if the oil filler cap is removed with the engine running. Their is also some leakage from the rear crank seal which leaves drips on the ground and some times seems to get on the clutch as it can judder if the car has been standing for some weeks. A few years ago I replaced the rocker shaft so their is no excessive oil flying around the rocker box.
Also few years ago I purchased a PCV Valve mainly to try to stop the leakage from the rear crank seal. Howver on fitting the engine went from running fine to running very poorly especially on tick over. I took the Valve off it the engine once again ran fine immediatlely.
Its cold here in Southern England so I thought it may be time to have another try,and of course same result immediate poor running.
I have connected the valve via a rubber pipe and connector provided with the kit to the T piece of the rocker box and to the small drilling (normally plugged) on the manifold which I suspect may have been for a vacum gauge.
If I disconnect at the T piece and put my finger over the end of the pipe (to the PCV) the engine immediatly runns fine again ,but the suction on my finger is considerable. Is this correct or could it be that the valve is not working correctly? The car does run reasonably at some revs and under load but not at tick over. Clearly there is now far more air getting into the cyclinders than before so I richened up both carbs by one whole turn but no noticable difference -so have now returned them to normal.
I can undertand that the carbs may need considerable adjustment to cope with the weaker mixture but dont really know 1,where to start 2,if perhaps the valve is faulty and 3,if its really worth the trouble.
Suggestions please. Sorry to be so wordy but thought it would be best to put the full facts in the first place
David Thorn - Near Bath England
