TR6 PCV valve attachment 69 TR6
ichthos
I was going crazy trying to find a vacuum leak on my 69 TR6, and I finally found the source: The PVC valve was just stuck into the inlet manifold and leaking air where it sits in the inlet manifold. It appears to have been glued in with something at one time. My question is is this the correct way to fit the PVC valve into the manifold? If so, what type of glue or gasket compound should be used? How long does it take to dry? I am going on a trip tomorrow night, so I would be especially delighted with any suggestions you may have. Thanks in advance.
Kevin
DNK
Kevin- Might be time, if you still want to run one, to pick one up from Moss. Just remove the old one and by pass it until the new arrives. $40 though, kind of steep.
As the website says. Get Two ,one for your toolbox. yea at that price I'd want to sell as many as I could.
I
ichthos
The valve itself is ok. I have a spare engine only a few serial numbers away, and the pcv valve is installed the same way - they used some type of glue or gasket compound. Seems kind of a funky way to attach this, but I guess on later models this unit was threaded. I am going to relace the diaphragm later, but for now I just need to know what type of glue or gasket compound to use to intall it back onto the intake manifold. I can't believe how I missed this problem and the impact on performance. Any suggestions on a type of glue or gasket compound?
Kevin
gjh2007
Mines a fairly tight fit on my 250, I would think just about anykind of silicon. An hr or so should be enough time to let it set up.
jehuie PCV valve explanation? British Motor Corp 5
steveg TR6 Adding a PCV valve Triumph 5
D Tri-carb PCV valve Austin Healey 61
C TR4/4A PCV Valve Triumph 0
S TR4/4A PCV valve Triumph 12
ttrotter PCV VALVE [or not!] 67 BJ8 Austin Healey 36
KVH TR4/4A pcv valve plus breather tube? Triumph 24
vette PCV Valve, Jumping in With Both Feet Austin Healey 17
D PCV Valve guts Spridgets 8
J TR2/3/3A Tr3-eary 4s, draft tube and /or PCV valve?? Triumph 13
Boink "Tuning" or dialing-in the pancake-style PCV valve Spridgets 9
L Oil in PCV valve Spridgets 30
R pcv valve for 1500 midget? Spridgets 18
N PCV valve query???? Spridgets 3
M pcv valve? Triumph 11
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
R TR4/4A TR4A Excessive oil consumption-PCV valve or ?? Triumph 9
RJS Smiths PCV Valve Differences? Triumph 2
wangdango TR6 '76 TR6 pcv valve, etc Triumph 3
M PCV Valve question Spridgets 1
abarth69 1275 PCV valve and oil leak Spridgets 7
Pythias PCV valve questions Spridgets 5
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
V New PCV valve from Moss Triumph 13
T pcv valve MG 2
S PCV Valve Triumph 2
5 PCV valve installation Austin Healey 10
B PCV Valve Tri Carb Austin Healey 11
CinneaghTR TR4/4A Wanted: TR4A PCV Valve Bracket Triumph 3
G How to rig a PCV valve on the Triple ZS setup..... Triumph 8
MadRiver Cleaning up a PCV Valve Triumph 5
U Rebuild a PCV Valve Rover / Land Rover 7
L MGB Need PCV valve for '69 MGB MG 2
D MGB PCV and charcoal canisters MG 0
M PCV and oil leaks Austin Healey 53
steveg PCV Valves - testing Austin Healey 8
C TR4/4A PCV System Triumph 4
N TR4/4A PCV hoses Triumph 5
D PCV System- What adjustments to make after fitting Austin Healey 18
TR4A_IRS Best adhesive for PCV diaphragm? Triumph 5
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
Boink PCV set-ups... can we discuss? Spridgets 18
P E Type V12 PCV & Smog systems Jaguar 8
R TR4/4A Tr4a rpm, with or w/o PCV Triumph 3
T Do I need a PCV assembly or can I just vent ? Triumph 7
doates Smith's PCV Triumph 1
Rut PCV installation results Spridgets 40
T Use PCV or just cap and vent? Triumph 15
Rut PCV installation Spridgets 55
boeingpilot TR4/4A TR4A PCV system Triumph 2
