Adding PCV valve to four cylinder
Dave Russell
Yoda - R.I.P
After trying several solutions to the crankcsse oil seepage/leakage problem I finally found one that actually works very well.
The Sixes do not have quite the same problem as the Fours. In the sixes a PCV valve can be inserted between the rocker arm breather to crankcase junction & the oil filter base. This provides a slght vacuum on the crank case under light to moderate throttle openings.
The Fours have a restricted valve cover outlet opening going to the air filter base joint in which a PCV valve could be inserted to provide a slight vacuum on the crank case under light to moderate throttle loadings. The filler cap is normally sealed, with the road draft tube providing necessary ventilation air. Much better than nothing.
A real solution. The carb to carb balance tube is drilled & tapped to accept a 5/15 fitting. This becomes the new source for the PCV valve inlet.
A tube is routed from this new manifold tap, through the added PVC valve, to the original valve cover breather outlet fitting. The original road draft tube is capped.
The PCV calibration allows a moderate vacuum to be pulled on the crankcase. The PCV calibration allows more flow as the throttle is opened. At worst case, full throttle, the valve prevents any build up of crankcase pressure, but never allows a positive presure in the crankcase.
Under actual tests, I show 5 inches of vacuum on the crankcase at idle to light throttle, 7 inches of vacuum at moderate to high throttle, & zero vacuum but no presure at full throttle.
Only a couple of flats on the carb main jet calibration were needed to bring things back into balance.
No more oil leaks from the engine. When the engine is shut off you can hear several seconds of vacuum leak into the crankcase.
I used a Napa #2-2982 PCV vave. A pic is attached.
mjobrien
Dave,
This is a great idea and anything that keeps Oil on the inside of 100's engine is a good thing. The "tee" I assume connects the Valve cover, Air Breather and Balance Tube? With the Crank vent blocked off....
Michael
55 BN1......
Dave Russell
Dave Russell
Yoda - R.I.P
The original valve cover baffled side vent is connected to the large diameter side of the new PCV valve via a short large diameter hose. The right angle plastic PCV valve outlet is connected back to the new intake manifold connection.
The straight PCV valve plastic connection is capped.
Not shown is an added right angle hose nipple in the oil filler cap which allows connecting a temporary vacuum gage to monitor actual vacuum levels under various driving conditions. This connection is normally capped.
roscoe
Dave,
that is elegant. Thanks for the R & D. Do you think I could use the capped portion of the tee fitting to run a line to my front shock absorbers? It would be easy to put a nipple on the filler plug and keep a vacuum on the shocks to keep the oil in them too!
steveg TR6 Adding a PCV valve Triumph 5
Frameman 1949 Adding an Ammeter Austin Healey 67
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
D Adding hardener to Rusroleum Restoration & Tools 5
G Adding a Brake Booster / Brake Calipers Austin Healey 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
M TR6 Adding Some Power Triumph 8
R Adding attachments to your Post FORUM Navigation Questions 1
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
I adding a second fuel pump Austin Healey 16
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
vping T-Series Adding a battery cut off switch. MG 16
Geo Hahn Adding Diode to OD Wiring Triumph 2
M Adding Picture FORUM Navigation Questions 2
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
M Adding Disc Brakes to a BN2 Austin Healey 7
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
jvandyke thoughts on adding vacuum ports to carb spacers Spridgets 2
theleisure Wiring Question, Adding Reverse Spotlight Spridgets 9
T TR6 Adding lightness to a TR6 Triumph 26
K Adding a Radio BN7 Austin Healey 7
AltaKnight Adding JAM Triumph 22
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
Geo Hahn Adding a Headlamp Relay Triumph 19
N Adding an O2 sensor to exhaust? Triumph 25
P Adding pictures? Triumph 15
B Adding lap belts Spridgets 14
OregonTR4A Adding gear oil to the gearbox? Triumph 8
Tronch Adding Fuses Austin Healey 4
19_again adding pix to a post MG 6
vping Adding OD to my '67 MG 23
jjbunn Adding a vacuum gauge MG 18
drooartz Adding a bike Other Cars 40
tony barnhill Still "Adding Lightness" MG 39
S TR4/4A Adding overdrive to tr4 Triumph 7
