Adding a Radio BN7
KevinBN7
Member
Hello Listers. I would like your opinions about adding a radio to my Healey.
With the copper spark plug wires will I have feedback/static through the radio. I use Resistor plugs.
Are front and back speakers neccesary or will back ones do fine?
My main intention will be using an Ipod. But the radio will be used occasionally. I will not externally mount the antena but put it in the boot or under dash.
Last year I used a set of 12V computer speakers with my Ipod whick worked fine until abour 50 mph.
Motorcycles have an automatic volume control that is quieter at low speeds/stopped and gains volume with speed. Ss any one familiar with this or have tried to used one?
I am looking forward to another great summer of owning this car.
Thank you for any input or opinions you can share.
Kevin
I have to go snowblow my driveway AGAIN
GregW
I was going to post a reply, but I see Ausmhly reading this thread. He posted a good solution awhile back, can't remember the name of the thread though.
AUSMHLY
Hi Kevin,
Or as you say, hello listers. Is that a pun relating to your topic? Right on!
A lot of good questions.
Others may help you with the spark plug question.
Speakers, how or where do you plan on installing them? What kind of speakers?
Speaker placement affects acoustics as in bad placement, no bass, or hardly any db's. How much power does the radio or amp provide to the speakers. How much power will the amp require of your generator if you're still running one.
I have not heard of an antenna that works in a trunk or under a dash. Maybe something new? Other may chime in on that.
I have two sets of computer speakers installed under my dash and they sound great. They are self powered and attached to a Garmin Nuvi 660 via the headphone jack. The under dash area, helps with the bass. I think any sound system installed in a Healey will have volume problems over 50 mph. I do.
I have an automatic volume control and it works great. It's my right thumb and index finger.
Here's a couple photos of my speaker installation. Maybe it will give you some ideas.
Happy motoring!
Roger
AUSMHLY
Hey Greg,
Warn us to put on our sunglass's.
Bling...Baaaaling.
And in wide screen for your viewing pleasure!
Nice carb set up.
R.
Jerry
I am thinking of putting my radio in the trunk. Perhaps behind the wall that the front of the battery sits againist, in with the gas tank tube. That is dead space and new radios can be purchased with a remote control. then I don't have to see the radio and the speakers can be hidden in many places. I do like the idea of a hot rod antenna hidden under the shroud.
Jerry
BJ8
Morris56
In my younger days, I stuffed a a 10" fosgate sub, two Infiniti Kapa 6x9's and a pair of infiniti front separates into my MGB... oh yea - powered by 3 separate amps. I was 16 and sound systems were in. I learned a lot from that experience... # 1 of which was that this was a big waste of time and money... #2 bass is minimal in a convertable... and #3 without a rear shelf - rear speakers just end up blowing into the back seats.
On my Healey... I will just be working on the front. When I order my interior kit... I will ask for enough extra vinyl to build a 2nd set of door panels. I will use separtes (5 1/4 drivers... maybe 6.5 if I can find a good location). Directionally aiming the tweeters is the most important which is what makes seperates nice to work with (tweeters are only about an inch wide so they are easy to hide).
I want to keep a period look to the dash, so I will probably butcher an old radio to work as controls for a CD player or line-in controls for an MP3 player. I listen to more NPR than radio anymore (guess that's starting to show my age) so a radio will not be an issue for me. If you can give up the radio, an easy solution is a line-in controller for an amplifier. Install an amp and the controller up under the dash with just a small cable for hookup to the IPOD showing.
as far as the feedback - yes that was a problem for me too... but they sell very inexpensive isolators that you can run in-line that will eliminate 95% of the noise.
Hope this helps
K
KevinBN7
Member
A remote radio solves alott of issues. Since I am in the planning stage that is a great suggestion. The Ipod has it own volume control as well but it is wired.
The BN7 has plenty of room in the cargo area behind the seats. I dont carry a spare tire and have made a panel that covers the opening for it. I can either cut speakers into that panel or use box speakers. I prefer box speakers that are removeable if I show the car. I made one panel I could make another to use for speakers.
I might need to up my budget and renegotiate with my minister of finance
KR
kevinbn7, try searching this topic in the archives gregw. myself and several others posted a bunch of pictures of speakers and their placement, should be helpful to you. :savewave:
Frameman 1949 Adding an Ammeter Austin Healey 67
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
D Adding hardener to Rusroleum Restoration & Tools 5
G Adding a Brake Booster / Brake Calipers Austin Healey 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
steveg TR6 Adding a PCV valve Triumph 5
M TR6 Adding Some Power Triumph 8
R Adding attachments to your Post FORUM Navigation Questions 1
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
I adding a second fuel pump Austin Healey 16
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
vping T-Series Adding a battery cut off switch. MG 16
Geo Hahn Adding Diode to OD Wiring Triumph 2
M Adding Picture FORUM Navigation Questions 2
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
M Adding Disc Brakes to a BN2 Austin Healey 7
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
jvandyke thoughts on adding vacuum ports to carb spacers Spridgets 2
theleisure Wiring Question, Adding Reverse Spotlight Spridgets 9
T TR6 Adding lightness to a TR6 Triumph 26
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
AltaKnight Adding JAM Triumph 22
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
Geo Hahn Adding a Headlamp Relay Triumph 19
N Adding an O2 sensor to exhaust? Triumph 25
P Adding pictures? Triumph 15
B Adding lap belts Spridgets 14
OregonTR4A Adding gear oil to the gearbox? Triumph 8
Tronch Adding Fuses Austin Healey 4
19_again adding pix to a post MG 6
vping Adding OD to my '67 MG 23
jjbunn Adding a vacuum gauge MG 18
drooartz Adding a bike Other Cars 40
tony barnhill Still "Adding Lightness" MG 39
S TR4/4A Adding overdrive to tr4 Triumph 7
