PCV valve installation
57_100_6
Member
Don't have my tech talk book handy and was wondering if anyone had a picture or description for installing PCV valve to keep the crankcase pressure in check. Will any PCV valve work?
Thanks
/bcforum/images/%%GRAEMLIN_URL%%/driving.gif
Keoke
57_100_6 said:
Don't have my tech talk book handy and was wondering if anyone had a picture or description for installing PCV valve to keep the crankcase pressure in check. Will any PCV valve work?--------NO!
Thanks
I have tried many different valves with out much success. The problem I experienced is the valve would work at low speeds but fail at speed actually building crankcase pressure.--Fwiw---Keoke
Johnny
Doesn't the tube running from the block up to the valve cover then on to the carbs serve that purpose?
Keoke
Well almost Johnny, but it can be improved on.
Lin, I used that same PCV that Kock sells and the reference also cited would not work for me. Except at low speeds---Keoke-??
Lin
Keoke,
Since my engine is yet to be installed I cannot say anything about how the PCV might or might not work. I will let you know late summer or early fall if all oes well! I do have the valve to try.
Cheers
Lin
Hangtown Healey
I put a PCV system on my BJ8 as described in a 1970's Healey Highlights club magazine. It seems to work. I did it in the 70's. I don't remember if I really tried testing it. I do shake the valve once in awhile to verify the little ball is still loose. The valve is for an old Chevy straight six. To test a PCV system, one can put a pice of paper over the oil filler hole in the valve cover and observe if it blows out or in.
57_100_6
Member
Thanks for all of the input on this subject. I am going to give it a try seeing it won’t hurt anything and I have heard of good results from various other older cars using this method.
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Please explain to me why you would want a PCV valve. I took one off my MGB (as many of us did in the 70's)'cause of several failures.
Keoke
Hi TH, It is easier than installing a rear engine oil seal if you can get it to work. Theoretically it will invert the pressure in the crank case. The failures you allude to were the result of owners failing to service the valve hence they would stick shut.--Fwiw--Keoke
Dave Russell
Yoda - R.I.P
The PCV is quite helpful on an engine that is designed for it. Although it's original intent was to keep blow by fumes from escaping to the atmosphere, the PCV maintains a slight vacuum on the crankcase. This vacuum instead of pressure in the crankcase helps reduce the oil leaks.
The type "A" valve is closed at idle, open at cruising power, & partially closed at full power. The valve flow rate, calibration, & air intake vent for the crankcase must be sized to the particular engine. Mid range jetting/fuel flow might need to be increased to compensate for the extra air going into the manifold at cruising power.
Some folks get it to work on Healeys, some don't. I haven't bothered to try, but if I had one that was working, I wouldn't remove it.
I think the Nock recommended connection method for the Sixes (connecting both bottom & top vents to the PCV) does not allow for air intake to the crankcase. A better method would be to connect the PCV to the crankcase vent only & leave the valve cover vent open to atmosphere as it is presently connected to the air filter. Maybe with a properly sized restrictor. A type "A" PCV from a similar sized engine should match up pretty well.
This would allow for controlled air circulation in through the valve cover, through the engine, & out through the lower crankcase vent & PCV to the intake manifold.
jehuie PCV valve explanation? British Motor Corp 5
steveg TR6 Adding a PCV valve Triumph 5
D Tri-carb PCV valve Austin Healey 61
C TR4/4A PCV Valve Triumph 0
S TR4/4A PCV valve Triumph 12
ttrotter PCV VALVE [or not!] 67 BJ8 Austin Healey 36
KVH TR4/4A pcv valve plus breather tube? Triumph 24
vette PCV Valve, Jumping in With Both Feet Austin Healey 17
D PCV Valve guts Spridgets 8
J TR2/3/3A Tr3-eary 4s, draft tube and /or PCV valve?? Triumph 13
Boink "Tuning" or dialing-in the pancake-style PCV valve Spridgets 9
L Oil in PCV valve Spridgets 30
R pcv valve for 1500 midget? Spridgets 18
N PCV valve query???? Spridgets 3
M pcv valve? Triumph 11
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
R TR4/4A TR4A Excessive oil consumption-PCV valve or ?? Triumph 9
RJS Smiths PCV Valve Differences? Triumph 2
wangdango TR6 '76 TR6 pcv valve, etc Triumph 3
M PCV Valve question Spridgets 1
abarth69 1275 PCV valve and oil leak Spridgets 7
Pythias PCV valve questions Spridgets 5
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
I TR6 PCV valve attachment 69 TR6 Triumph 5
V New PCV valve from Moss Triumph 13
T pcv valve MG 2
S PCV Valve Triumph 2
B PCV Valve Tri Carb Austin Healey 11
CinneaghTR TR4/4A Wanted: TR4A PCV Valve Bracket Triumph 3
G How to rig a PCV valve on the Triple ZS setup..... Triumph 8
MadRiver Cleaning up a PCV Valve Triumph 5
U Rebuild a PCV Valve Rover / Land Rover 7
L MGB Need PCV valve for '69 MGB MG 2
D MGB PCV and charcoal canisters MG 0
M PCV and oil leaks Austin Healey 53
steveg PCV Valves - testing Austin Healey 8
C TR4/4A PCV System Triumph 4
N TR4/4A PCV hoses Triumph 5
D PCV System- What adjustments to make after fitting Austin Healey 18
TR4A_IRS Best adhesive for PCV diaphragm? Triumph 5
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
Boink PCV set-ups... can we discuss? Spridgets 18
P E Type V12 PCV & Smog systems Jaguar 8
R TR4/4A Tr4a rpm, with or w/o PCV Triumph 3
T Do I need a PCV assembly or can I just vent ? Triumph 7
doates Smith's PCV Triumph 1
Rut PCV installation results Spridgets 40
T Use PCV or just cap and vent? Triumph 15
Rut PCV installation Spridgets 55
boeingpilot TR4/4A TR4A PCV system Triumph 2
