PCV valve questions
Pythias
Go back in time...
When I had my 1098 (10cc 2" mains) rebuilt, it came back WITHOUT the little pancake breather thing. It shows up in pics of the Holy Sprite. Instead a rubber hose was run directly from the manifold to the cannister. ?
After years of running this configuration, I've finally located a replacement, with a good diaphram.
The Question.. to what end? What is the purpose of the pancake thingy? Will putting it back in the system relieve high crankcase pressure? I tend to blow more oil at high rpms's .. will it help? does it hurt? .. what's the Dealeee-O?
Jim_Gruber
Without that on Bugsy's 1098 I had the Exxon Valdez with oil coming out the rear seal. THe PCV valve fixed all of thiat on my 1098.
jvandyke
FWIW
My '63's 1098cg (earlier than yours) had hose from rocker cover to Weber's air filter housing and a pipe coming out of the side cover inspection plate down toward the road. It leaked out of the this pipe.
I drilled and tapped a hole in the intake manifold and used that instead of air filter housing. Leak stopped. Mine predates the timing cover vent and the cannister equipped inspection cover pipe but even so, it doesn't leak anymore from anywhere except one spot that I'm 90% sure is the fault of the spin-on filter adapter rig job.
Jer
Wow ! I can't believe you weren't smoking out a city block 24/7 without the pcv valve :smile: -
My pcv valve was faulty on my '67 (1275cc) when I bought it - same configuration as your 1098 though as the new style pcv system came out in 68 or 69 I think ... anyways - with my faulty valve if I stopped hard causing oil to slop forward it would smoke out a small town & if it was going down a steep slope or under load I would rid the area of bugs for the year.
Ordered a complete new PCV from Moss & haven't had an issue since. Not sure exactly how the valave works but there is a diaphram & spring so I would have to assume that it regulates the flow of crankcase gases/pressure as the intake vaccum increases/decreases...
Pythias
Pythias
Turns out the builder put some sort of small inline PCV valve screwed directly into the manifold where the nipple for the pancake type usually goes. I thought there was NOTHING there. I found it when I pulled the hose to do the pancake installation! Who KNEW?
jvandyke
On mine, I restricted the hole size so maybe that helps keep the oil ingestion to a minimum. I think this was pretty common as my 1970 Opel's 2,0 CIH motor had the same set up, small diameter hose from valve cover right to intake, hooked to a very small ID tube.
jehuie PCV valve explanation? British Motor Corp 5
steveg TR6 Adding a PCV valve Triumph 5
D Tri-carb PCV valve Austin Healey 61
C TR4/4A PCV Valve Triumph 0
S TR4/4A PCV valve Triumph 12
ttrotter PCV VALVE [or not!] 67 BJ8 Austin Healey 36
KVH TR4/4A pcv valve plus breather tube? Triumph 24
vette PCV Valve, Jumping in With Both Feet Austin Healey 17
D PCV Valve guts Spridgets 8
J TR2/3/3A Tr3-eary 4s, draft tube and /or PCV valve?? Triumph 13
Boink "Tuning" or dialing-in the pancake-style PCV valve Spridgets 9
L Oil in PCV valve Spridgets 30
R pcv valve for 1500 midget? Spridgets 18
N PCV valve query???? Spridgets 3
M pcv valve? Triumph 11
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
R TR4/4A TR4A Excessive oil consumption-PCV valve or ?? Triumph 9
RJS Smiths PCV Valve Differences? Triumph 2
wangdango TR6 '76 TR6 pcv valve, etc Triumph 3
M PCV Valve question Spridgets 1
abarth69 1275 PCV valve and oil leak Spridgets 7
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
I TR6 PCV valve attachment 69 TR6 Triumph 5
V New PCV valve from Moss Triumph 13
T pcv valve MG 2
S PCV Valve Triumph 2
5 PCV valve installation Austin Healey 10
B PCV Valve Tri Carb Austin Healey 11
CinneaghTR TR4/4A Wanted: TR4A PCV Valve Bracket Triumph 3
G How to rig a PCV valve on the Triple ZS setup..... Triumph 8
MadRiver Cleaning up a PCV Valve Triumph 5
U Rebuild a PCV Valve Rover / Land Rover 7
L MGB Need PCV valve for '69 MGB MG 2
D MGB PCV and charcoal canisters MG 0
M PCV and oil leaks Austin Healey 53
steveg PCV Valves - testing Austin Healey 8
C TR4/4A PCV System Triumph 4
N TR4/4A PCV hoses Triumph 5
D PCV System- What adjustments to make after fitting Austin Healey 18
TR4A_IRS Best adhesive for PCV diaphragm? Triumph 5
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
Boink PCV set-ups... can we discuss? Spridgets 18
P E Type V12 PCV & Smog systems Jaguar 8
R TR4/4A Tr4a rpm, with or w/o PCV Triumph 3
T Do I need a PCV assembly or can I just vent ? Triumph 7
doates Smith's PCV Triumph 1
Rut PCV installation results Spridgets 40
T Use PCV or just cap and vent? Triumph 15
Rut PCV installation Spridgets 55
boeingpilot TR4/4A TR4A PCV system Triumph 2
