PCV Valve question
M
Mike
Apparently my PCV Valve was removed from my 1275 A engine on my 58 Bugeye long before I got her. A mechanic told me that I would need a new manifold and the valve assembly to reinstall. He also says this was common on these engines and the removal has added pressure which can lead to a oil leak out the spiral track in the rear of the engine. Does this make since? Is this an expensive fix. I prefer to work on my Bugeye myself, is this something that's fairly easy to do?
Thanks,
Mike
Woblynne
Member
Hi, it shouldnt be too bad a job. If you have the original style inlet manifold without the fitting for the valve you may be able to get it tapped to accept the pcv valve (item 62 in the link).
All parts should be available to do this whether they're new or second hand. If buying used I would get a new diaphragm (item 67) cause if this is torn the set-up wont work correctly
https://www.moss-europe.co.uk/Shop/ViewProducts.aspx?PlateIndexID=1418
You would also need the cannister on the front timing chain cover which connects to the pcv via a rubber hose, to draw vacuum from the block.
HTH
Mark
jehuie PCV valve explanation? British Motor Corp 5
steveg TR6 Adding a PCV valve Triumph 5
D Tri-carb PCV valve Austin Healey 61
C TR4/4A PCV Valve Triumph 0
S TR4/4A PCV valve Triumph 12
ttrotter PCV VALVE [or not!] 67 BJ8 Austin Healey 36
KVH TR4/4A pcv valve plus breather tube? Triumph 24
vette PCV Valve, Jumping in With Both Feet Austin Healey 17
D PCV Valve guts Spridgets 8
J TR2/3/3A Tr3-eary 4s, draft tube and /or PCV valve?? Triumph 13
Boink "Tuning" or dialing-in the pancake-style PCV valve Spridgets 9
L Oil in PCV valve Spridgets 30
R pcv valve for 1500 midget? Spridgets 18
N PCV valve query???? Spridgets 3
M pcv valve? Triumph 11
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
R TR4/4A TR4A Excessive oil consumption-PCV valve or ?? Triumph 9
RJS Smiths PCV Valve Differences? Triumph 2
wangdango TR6 '76 TR6 pcv valve, etc Triumph 3
abarth69 1275 PCV valve and oil leak Spridgets 7
Pythias PCV valve questions Spridgets 5
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
I TR6 PCV valve attachment 69 TR6 Triumph 5
V New PCV valve from Moss Triumph 13
T pcv valve MG 2
S PCV Valve Triumph 2
5 PCV valve installation Austin Healey 10
B PCV Valve Tri Carb Austin Healey 11
CinneaghTR TR4/4A Wanted: TR4A PCV Valve Bracket Triumph 3
G How to rig a PCV valve on the Triple ZS setup..... Triumph 8
MadRiver Cleaning up a PCV Valve Triumph 5
U Rebuild a PCV Valve Rover / Land Rover 7
L MGB Need PCV valve for '69 MGB MG 2
D MGB PCV and charcoal canisters MG 0
M PCV and oil leaks Austin Healey 53
steveg PCV Valves - testing Austin Healey 8
C TR4/4A PCV System Triumph 4
N TR4/4A PCV hoses Triumph 5
D PCV System- What adjustments to make after fitting Austin Healey 18
TR4A_IRS Best adhesive for PCV diaphragm? Triumph 5
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
Boink PCV set-ups... can we discuss? Spridgets 18
P E Type V12 PCV & Smog systems Jaguar 8
R TR4/4A Tr4a rpm, with or w/o PCV Triumph 3
T Do I need a PCV assembly or can I just vent ? Triumph 7
doates Smith's PCV Triumph 1
Rut PCV installation results Spridgets 40
T Use PCV or just cap and vent? Triumph 15
Rut PCV installation Spridgets 55
boeingpilot TR4/4A TR4A PCV system Triumph 2
