Main Bearing Seal Leaking
Jman
I recently had the engine rebuilt in my '66 AH sprite, and the main bearing seal is leaking like crazy. I did a search to see if there was anyone else having problems w/ the cork seals but came up empty. Is there a secret to installing them so they dont leak? Any suggestions would be greatly appreciated.
Thanks
Jman
Only leaks when the engine is running, basically pours out. My mechanic said that he was pretty sure he had installed them right, but he asked me to find out if there was a proven process.
Front and rear both? Oh yea and it is a 1275 I think.
Is it really leaking from the front and back of the oil pan or just where?
If pan he did not install the cork gaskets front and rear properly.
There is no main bearing seal on an A Series engine. There is a scroll cut on the crank that is supposed to "wind" the oil back into the engine. If the mechanic disturbed the scroll cover on the rear of the block, and didn't get it re-set properly, there can be a massive leak while running.
You may just have an oil pan leak.
Jack, a '66 should have a "big crank" 1098 in it.
Jeff
Jeff
I was going to break it to him slowly. The threaded dealy that winds the oil works good when running, but not so good when its stopped and oil runs down. Sounds like he has worse problems. Hopefully its just the pan gaskets, just drop it and fix, otherwise the motor will have to come out or at least be raised for that front seal. There is a front main rubber lip seal.
Yea, I was kinda working up to that as well.
I for some reason can not remember what engines go with what years, need to write it down.
Jack:
948: 1958 ~ 1962
1098:
Small crank, 1963 ~ 1964
Big crank, 1965 ~ 1966
1275: 1967 ~ 1974
1500: 1975 ~ End of Production.
Jeff
No matter what year/displacement he needs to remove the oil filler cap (cover the hole with a clean rag and a couple of rubber bands) and see if the oil leakage suddenly slows down, if it does I think that there may be a PCV question. I've seen it too many times.
Bill
Ok Jeff, printed that and will post it, hehe. Thanks.
Alot of good advice here, I'll add something to the frey, when getting a bottom end gasket set for a 1275, get the better Payen set with the rubber pan rail end gaskets in it, they do a much better job than the cork. Also mentioned here is venting the crankcase. IF your problem keeps getting worse it could be that the rings are not seating.
Thanks Fellas, It's a 1098. The front isnt leaking. Its the rear main seal, I'm pretty sure its not the pan seal. I'll have to look and see what you are talking about with the scroll deal. At least now I have some info to take to him on monday. I took him the engine in pieces in a wash tub, and he had never messed w/ an AH before, so we kinda just winged it. I guess it could be worse!
Thanks
Jman
Is a link someplace on building a no leaker, not sure if that applies however. He did have some preaty detailed instructions on the scroll seal cover thing.
Sure it is, glad you guys have better memories than I.
Think the 66 took engine oil in the transmission as well.
Hey guys, I hate to bump a thread that's this old but I finally had a chance to work on my sprite again and removed the seal that my mechanic had put in. Worked like a charm. No more leaks and the engine runs great. Thanks for the great advice.
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
J General TR Main bearing caps Triumph 6
R Main Bearing Cap Removal Austin Healey 12
D BT7 main bearing seals Austin Healey 11
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
A 100 engine main bearing cap nut question Austin Healey 0
oxford main bearing caps Austin Healey 4
M Healey 100-4 NOS Main Bearing Concerns Austin Healey 3
W 100-4 front main bearing cap issue Austin Healey 5
G TR6 TR6 main bearing torque Triumph 7
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
rikiwho123 Main Bearing Cap Bolts Triumph 6
F Main / Rod bearing sizes. Spridgets 6
M Main Bearing Cap Question Spridgets 2
Bruce_B Locktabs on Main Bearing Bolts? Spridgets 3
healeynut Main Bearing Caps - 100 Austin Healey 7
vping Main bearing cap puller Restoration & Tools 0
B Main Bearing on 3000 Austin Healey 3
T .050" main bearing source MG 1
S Main Bearing caps Austin Healey 4
S Main bearing thrust washer ? Spridgets 3
S Main Bearing Replacement Austin Healey 8
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 13
Gerard 1098 10CC rear main seal conversion Spridgets 4
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
