Main bearing thrust washer ?
StevenA
Long story = short. MG Midget, 1976 built in 11-75, 1500, original engine, 34,760 miles, stored for 18 years, re-build from ground up, Engine rebuild... The thrust washer was in the oil pan when I took the engine apart. Putting all new gaskets, washers, seals, etc in rebuild... the thrust washer goes on top of the crank to the rear of the engine block.
What keeps that little sucker in place? I put it together and turned it over( with starter hook up and battery while still on engine stand) and found that it would barely turn/ if at all. I took the bearing caps off and went to re-install them and found the washer lying on the floor next to my engine stand. Engine is very tight and will crank slowly with starter and new battery. Also replaced the piston rings.
aeronca65t
The 1500 is a Triumph-designed engine, and like all TR engines, it has a tendency to kill thrust washers. I change the thrust washers in my 1500 race-Spridget every two years or sooner.
They should stay in place because they are "trapped" between the block and the crank cheek. If they become worn, they fall out. Once they fall out, the crank rubs on the block, creating all sorts of havoc. If you've put new ones in and they fell out straight away, you may have a damaged or worn crank cheek or adjacent block area....a bad situation.
New thrust washers are available in .005" and .015" oversize, if the damaged area can be remachined.
I'm concerned about your comment that the engine is "tight". Are you installing the washers correctly? (and I'll assume that you are not using oversize thrust washers in a "standard" setup).
Also, be sure that the ring gaps are about right (roughly .005" to .010") and that they were installed in clean piston grooves.
If you have installed new bearings, be sure they are the correct size (have the crank journals been turned down?).
Here's a story about TR6 thust washers (similar to the 1500 design):
https://users.arczip.com/zntech/tr6.html
More info:
https://www.teglerizer.com/triumphstuff/thrustwashers.htm
Here's a way that one fellow make's the thrust washers "stay put" (not sure I'd do this):
https://www.tr6web.com/Documents/tr6/mjbtwasherfix.html
A similar "stay put" ploy:
https://www.geocities.com/MotorCity/Speedway/1080/thrustwasherinstall.html
Here's a picture of the thrust washers...shown as "28" in this Moss picture (you probably already have a similar picture in your manual):
S
StevenA
I didn't have anything machined due to the true mileage of the engine (under 40,000 miles) but possibly should have. I am going to try again this afternoon and see if I can tell if there is undue wear anound the crank. My concern was that I couldn't see anything that kept it in place and I guess I should just pull it apart and start over instead of trying to fix it in place. Just hated to undo all the work to this point. I had clean (very clean) engine parts throughout, ring grooves were fine, rings were atandard stock replacement, gaskets seals and misc were also stock since there was so little wear. It ran great but smoked, so I tore it down mainly to replace rings and since it was apart... why not everything...??? I've done a bout a dozen engine rebuilds but not enough to feel near an expert. My local MG shop is 45 miles away so I do more on my own than having it done.
S
StevenA
PS.... Thanks... I think you answered exactly what I needed and the links were great. I'll be out in the garage in a few minutes and check back tonight to see if all was successful.
Cheers, Steve
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
J General TR Main bearing caps Triumph 6
R Main Bearing Cap Removal Austin Healey 12
D BT7 main bearing seals Austin Healey 11
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
A 100 engine main bearing cap nut question Austin Healey 0
oxford main bearing caps Austin Healey 4
M Healey 100-4 NOS Main Bearing Concerns Austin Healey 3
W 100-4 front main bearing cap issue Austin Healey 5
G TR6 TR6 main bearing torque Triumph 7
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
rikiwho123 Main Bearing Cap Bolts Triumph 6
F Main / Rod bearing sizes. Spridgets 6
M Main Bearing Cap Question Spridgets 2
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
Bruce_B Locktabs on Main Bearing Bolts? Spridgets 3
healeynut Main Bearing Caps - 100 Austin Healey 7
vping Main bearing cap puller Restoration & Tools 0
J Main Bearing Seal Leaking Spridgets 19
B Main Bearing on 3000 Austin Healey 3
T .050" main bearing source MG 1
S Main Bearing caps Austin Healey 4
S Main Bearing Replacement Austin Healey 8
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
