main bearing caps
oxford
Hi all
can anyone give me any clues on removing the main bearing caps? I know I have to make a puller, but the rear one doesn't have a built in thread because of the oil drain tube. Should I make a puller with the large thread or is there another way.
Thanks
Matthew
EV2239
It's a very long time since I did mains on a Healey, but I think I just tapped them to loosen them and then just yanked them out. That's all i had to do with a TR3A engine the other day.
You can thread an NPT 1/2" bush into the rear main cap, and thread the inside of the bush with the same size as the holes in the other three (3) main caps.
That's a main bearing cap stud/nut being used with the puller.
bob hughes
Much the same as Randy but I just bolted in a piece of angle iron into the sump fixing hole/holes in the cap and had another hole in the web of the angle to put in my slide hammer hook, came out a treat.
:cheers:
Bob
J General TR Main bearing caps Triumph 6
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
healeynut Main Bearing Caps - 100 Austin Healey 7
S Main Bearing caps Austin Healey 4
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
R Main Bearing Cap Removal Austin Healey 12
D BT7 main bearing seals Austin Healey 11
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
A 100 engine main bearing cap nut question Austin Healey 0
M Healey 100-4 NOS Main Bearing Concerns Austin Healey 3
W 100-4 front main bearing cap issue Austin Healey 5
G TR6 TR6 main bearing torque Triumph 7
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
rikiwho123 Main Bearing Cap Bolts Triumph 6
F Main / Rod bearing sizes. Spridgets 6
M Main Bearing Cap Question Spridgets 2
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
Bruce_B Locktabs on Main Bearing Bolts? Spridgets 3
vping Main bearing cap puller Restoration & Tools 0
J Main Bearing Seal Leaking Spridgets 19
B Main Bearing on 3000 Austin Healey 3
T .050" main bearing source MG 1
S Main bearing thrust washer ? Spridgets 3
S Main Bearing Replacement Austin Healey 8
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
