Skip,
There is likely to be some disagreement on this, but I think that it is one of those belt plus suspenders things. I don't think lock nuts on main bearing studs are needed in the first place. When you consider how little the joint can flex & the amount of tension used, the locking nut isn't really doing anything. You don't see lockwashers on head bolts which is a similar type of joint.
As far as replacing the Nylocks, what ever you are comfortable with. A better lock would be green Loctite.
