General TR main bearing
Terry_M
Good morning
It's cold in Ontario this January morning I am collecting data and tools for my next DIY in the spring. Main bearing and thrust washers for my 74 TR6 I have an issue about crawling under and i am wondering if i should lift the whole car and where would i lift with a floor jack without causing damage
Any help /direction would be appreciated
terry
poolboy
You can do what you propose with just the front lifted high enough, but the more room the better for you and your maneuverability.
I should let someone else advise you about lifting points and supports...I don't want the responsibility.
Geo Hahn
The internet is chock-a-block with ideas for this:
But seriously, use good jack stands and/or something like this:
I use jack stands but sometimes I need both the front and back raised and having at least one end supported by wood cribbing makes the car feel especially solid & secure.
TR3driver
Great Pumpkin - R.I.P
And that picture is NEVER the way to do it. Buy some jack stands....good ones!
Amen to that! Way back with my first car (a non-LBC), I used cinder blocks as shown in Ken's photo. Worked great, until one day they both collapsed! Just suddenly returned to dust. Fortunately, I wasn't under the car at the time, but I would have been in just a minute or two...
T
Terry_M
I worry about getting caught under and squished like a bug I have sourced numerous jack stands although the cribbing looks very solid
Thanks
terry
charleyf
As to lifting points THE BOOK says to use the front cross member. This is the member that is directly behind the radiator protection cross bar. For the rear it says to use the pumpkin of the rear differential. Once the car is lifted to whatever height you wish I agree that we should use good quality jack stands. If you have been under you car before you will find that you need more room than you think. Which is saying that you need as much height as you can get. Those jack stands need to go underneath the frame both front and back. Ideally those positions should be on the frame inboard of the wheels of the car. Once the car is up on the jack stands gently shake it to make sure it is not going to move from where you have it. An improperly adjusted jack stand can give you a wobbly car. You do not want that. Get the car sitting solid before going underneath it.
Charley
bobhustead
While cinder blocks should never be used as jack stands, if you use them to support anything do not put the weight on a flat side as is shown in poolboy's first picture. In their intended use the holes are vertical, while in martial arts demonstrations they are horizontal. For good reason.
Bob
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
J General TR Main bearing caps Triumph 6
R Main Bearing Cap Removal Austin Healey 12
D BT7 main bearing seals Austin Healey 11
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
A 100 engine main bearing cap nut question Austin Healey 0
oxford main bearing caps Austin Healey 4
M Healey 100-4 NOS Main Bearing Concerns Austin Healey 3
W 100-4 front main bearing cap issue Austin Healey 5
G TR6 TR6 main bearing torque Triumph 7
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
rikiwho123 Main Bearing Cap Bolts Triumph 6
F Main / Rod bearing sizes. Spridgets 6
M Main Bearing Cap Question Spridgets 2
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
Bruce_B Locktabs on Main Bearing Bolts? Spridgets 3
healeynut Main Bearing Caps - 100 Austin Healey 7
vping Main bearing cap puller Restoration & Tools 0
J Main Bearing Seal Leaking Spridgets 19
B Main Bearing on 3000 Austin Healey 3
T .050" main bearing source MG 1
S Main Bearing caps Austin Healey 4
S Main bearing thrust washer ? Spridgets 3
S Main Bearing Replacement Austin Healey 8
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
