Locktabs on Main Bearing Bolts?
Bruce_B
Just double checking before I put the oil pan on my 1275 engine that I've rebuilt. See in a picture there's locktabs on the main bearing bolts--that I didn't put it.
I used the APR bolts--do I still need locktabs?
thanks...
Bugeye58
Bruce, you certainly don't need them. I assume you used the ARP toque recommendations and procedures?
I throw away every one of the cussed things I find.
Jeff
Bruce_B
Bruce_B
Thanks Jeff....thought I had read something like that....
Dave Russell
Yoda - R.I.P
Bugeye58 said:
Bruce, you certainly don't need them. I assume you used the ARP torque recommendations and procedures?
Jeff
I agree. If the tab is soft enough to be bent around a nut or bolt head, it will be soft enough to squeeze down & reduce bolt tension. If a flat washer is needed, it should be of the hardened variety.
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
J General TR Main bearing caps Triumph 6
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
R Main Bearing Cap Removal Austin Healey 12
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
D BT7 main bearing seals Austin Healey 11
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
KVH TR4/4A Real Main Seal and Pulling the Engine Triumph 19
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
Gerard 1098 "10CC" rear main Spridgets 0
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
S TR2/3/3A front main cap sticks proud Triumph 6
sim HUS 2 main jet adjustment Spridgets 40
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
A 100 engine main bearing cap nut question Austin Healey 0
B Rover V-8 main bearings Rover / Land Rover 5
KVH TR4/4A Viton Rear Main Seal Triumph 12
oxford main bearing caps Austin Healey 4
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
S TR2/3/3A tr3 rear main Triumph 24
