Rover V-8 main bearings
billca
I understand that the Rover V-8 engine main bearings in my 1972 Plus 8 Morgan can be changed by dropping the oil pan. Does anyone have experience and tips on doing this while the engine is still in the car?
I am relatively sure worn main bearings are my problem; I can hear dull knocking at low speed/full throttle and the oil pressure is very low at idle.
Thanks for any suggestions.
Billca
DNK
Dropped my pan in my Wedge a couple of times
Easy-Pezy.
Though ,have no idea how the cars are similar. So I guess no help
B
billca
Easy-Pezy.
When you dropped your pan did you replace any of the crankshaft main bearings? If you can do it on your car I think I can do it on my Morgan.
DNK
No I didn't change any bearings
The first time was to poder coat the pan. The second was to clean the pick up.
I know a bearing change has been done by many though.
One caveat, in a Wedge the crank has to be in a certain position
tr8todd
Once you drop the pan, it's easy to roll the bearings out one at a time and replace them. Remove the cap, half of the bearing should be inside the cap. Sometimes it will stick to the crank journal. Either way just pull it out. The top half will be a little tricky. You have to push it out. It will spin right around the journal and come out the bottom. You install the new ones by lubing them up with engine assembly lube and rolling them back in. You have to pay attention to the little notches that hold them in place, and make sure they go back into their little cutouts in the cap and block. There will most likely be a windage tray that has to come out as well, at least the later Rover V8s had one. Make sure you replace them one journal at a time, and spin the crank by turning the large bolt in the front balancer. Spin it after each journal's bearings are replaced. Watch out for the thrust washer. Can't remember where it goes, but you'll see it.
B
billca
tr8todd,
Thanks for the advice. Sounds simple enough and I'll give it a try.
Billca
J Land Rover research Rover / Land Rover 4
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
F For Sale Rover V8 blocks for sale Other British Classifieds 1
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
CJRams For Sale 1996 Rover MGF 1.8i - $15,000 MG Classifieds 3
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
D Land Rover engine swop. Rover / Land Rover 1
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
A MGB Donor Rover 3500 P6B for my MGB MG 5
albertemore Range Rover Classic Parts? Rover / Land Rover 5
G Rover P3 Brake Lining - Front Rover / Land Rover 2
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
PAUL161 Land Rover 73 Rover / Land Rover 0
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
Steve Range Rover Evoque Convertible Rover / Land Rover 2
LarryK Land Rover Repair or just plain how to! Rover / Land Rover 1
catfood Land Rover Evoque Convertible Spotted 1
aeronca65t Landwind - fake Rover Rover / Land Rover 3
Steve Land Rover 90 vs. Dodge Ram Rover / Land Rover 1
Boink First Range Rover Rover / Land Rover 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
K Land Rover Defender - Mountain Rescue Team Rover / Land Rover 0
N Land rover and coffman cartridge starter Rover / Land Rover 0
HealeyRick A Visit to the Land Rover Factory Rover / Land Rover 0
G Rover 3.9 info?? Rover / Land Rover 1
JPSmit Land Rover Defender - and Home made special Spotted 1
aeronca65t Rover car carrier Rover / Land Rover 1
JPSmit Land Rover - hopefully good news. Spotted 9
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
aeronca65t Churchill's Land Rover For Sale Rover / Land Rover 1
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
Steve New Land Rover Defender Rover / Land Rover 9
58Custom Rover V8 in SoCal self-serve junkyard Rover / Land Rover 0
G Rover V8 interchange/swap question MG 9
rosalind Bye Old Rover...Hello new Rover Rover / Land Rover 2
aeronca65t Land Rover Forward Control Rover / Land Rover 0
T What car could use a Rover V8 Other Cars 3
Got_All_4 Wedge Rover 3.9 in a Tr7 Triumph 34
Steve Range Rover Evoque Rover / Land Rover 1
AngliaGT Rover 3500 Rover / Land Rover 1
M 2000 range rover????? Other British Cars 1
D 1935 Rover 10 wiring dia. and head lamp solonoid.. Rover / Land Rover 2
weewillie rover p6 and nissan skyline Spotted 0
racingenglishcars Land Rover collection for sale - in Norway, Dec 4 Rover / Land Rover 0
S Looking for a Rover 215 motor. MG 9
JPSmit Rover for sale Other British Cars 4
J Rover engine that started as Buick? Rover / Land Rover 9
