Looking for a Rover 215 motor.
ScottDavid82
I'm thinking about putting an Rover v8 in, or should I keep the 4 cyl.
And were can I find a Rover v8, there so darn hard to find.
tr8todd
Finding the motor is the easiest cheapest part. Finding the right timing cover, oil pan, intake, carb, flywheel, bell housing, headers, motor mount brackets, driveshaft, etc. is the expensive hard part. Good luck.
What year is your MGB? Rubber bumpered models usually require less engine bay/transmission tunnel than the chrome bumpered models.
Buick/Olds/Pontiac/Rover (BOPR) is what your after for the factory-style block.
Here's D&D's website: https://www.aluminumv8.com/
I used a Rover 3.9 litre and had it bored & stroked to about 5.0 litre.
And don't rule out the Ford 302. In all likelyhood, it may be less expensive oin the long run to use this motor.
I've also seen a couple of LS3 conversions.
You'll probably want a BorgWarner T-5 transmission. There are Ford and Chevy versions as well as V6 and V8 versions. Do you homework for what gear ratio will give you the performance you desire.
I used a T5 from a late 80's Camaro V8. It has a 0.63 final drive gear.
Your stock MGB 3.9 differential will most likely be strong enough for a stock BOPR or Ford 302. If you beef it up, you may want to look at a Ford or Dana differential
I used a Ford 8" from a late 70's Granada and had it narrowed. I also had an Auburn 3.27 positrack gearset installed.
You might want to peruse https://www.britishv8.org as it has a wealth of information to be discovered.
Safety/Faster!
Scott,
I am a ways from you, but I have a Buick 215 motor, complete down to the flywheel. Shipping would probably be has much as the cost of the motor but PM me if you are interested.
Marv
jclay
I will have a Triumph TR8 FI 3.5 available in a few months.
CurtisJ
The BritishV8 website has an active classified ad section, and at least one aluminum V8 has been listed for sale recently.
Lots and lots of Range Rovers in this area (near Denver), so it's hard for me to relate to people having trouble finding suitable motors locally.
tdskip
Scott - where in CA are you? I'm in SoCal and have a full set up including the rear axle, 5 speed and FI engine.
Drop me a PM is you are interested.
Mickey Richaud
Just to confuse the issue a bit, have you considered a GM V6? I'm in the beginning stages of converting a GT to a crate 3.4. Fewer hassles, and plenty of power on tap.
I wouldn't say there are fewer hassles with a V6 conversion...either conversion has its pros and cons...but there is nothing like the sound of a V8.
S
ScottDavid82
thanks for all the info guys. But we just had our baby, so my car plans are now on hold. Again thanks for the info.
philman Nice looking Rover on PDX Craigs List Rover / Land Rover 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
