MGB Donor Rover 3500 P6B for my MGB
AussieV8MGB
Hi all, I've read lots of information on here about different engines for a V8 swap, (sorry all the purists), and also using a better diff for the V8.
So do you think its possible to use the Engine, and diff from a 1976 Rover3500 P6B, and is there anything else i could use from the donor car?
Really appreciate any thoughts
Cheers Glenn
billspohn
You could use that motor but it is a pretty weak one in terms of output compared to more modern stuff, and I doubt there is anything else on the car that would be of use. You'd want a later Rover 5 speed no doubt and that would likely cost as much as the whole P6. The later SD1 spec were better, but you can still better it with a modest modern 4 cylinder or a V6. But it depends on what your goal might be. Either way it will cost you a lot of time and money so choosing a lacklustre engine to save a few bucks at the beginning doesn't make a lot of sense.
A
AussieV8MGB
Thanks Bill, Yeah the SD1 looks a better swap. I was just after the V8 grumble, more than the HP really, DO you know if the SD1s Diff is usable? as i think the ratio is a little higher that the 3500.
billspohn
The rear ends are very different and it would take a lot of work to fit the Rover rear end to the MG. Better to just buy a new gear set for your car - a longer ratio. Which axle do you have, banjo (early) or Salisbury (later). You can buy new gears to suit your needs or use some out of an MGC.
billspohn
The diff i have is a DeDion. The gears over in Aus are hard to come by and pretty expensive, but i'll keep on looking.
Really? That is different. What car is it out of?
The Salisbury late MGB diff has some weaknesses (thrust washers, usually) but it came from a small commercial vehicle so it is reasonably strong and ratios of 3.3 and 3.07 are available.
drooartz Viability of a parts/donor car Spridgets 6
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
boxofparts Looking for Donor Car in Michigan or Ohio MG 0
B Datsun 210 donor Spridgets 2
apbos Need a seat donor Spridgets 0
tinman58 Donor body found! Triumph 7
JPSmit nice donor drivetrain Spridgets 0
A MGB-GT New '69 GT Project, '67 donor car? MG 39
T 1275 donor for the Bugeye or stay with 1098? Spridgets 11
Baz I found a donor.... MG 16
Z Austin A70 Hampshire [1950] as a donor car Austin Healey 1
Dozuki Marina Manifold - Outake of 'Engine Donor' thread MG 4
Bret Engine donor selection question for rebuild? MG 18
jaybird Possible project/donor car MG 13
J Land Rover research Rover / Land Rover 4
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
F For Sale Rover V8 blocks for sale Other British Classifieds 1
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
CJRams For Sale 1996 Rover MGF 1.8i - $15,000 MG Classifieds 3
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
D Land Rover engine swop. Rover / Land Rover 1
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
albertemore Range Rover Classic Parts? Rover / Land Rover 5
G Rover P3 Brake Lining - Front Rover / Land Rover 2
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
PAUL161 Land Rover 73 Rover / Land Rover 0
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
Steve Range Rover Evoque Convertible Rover / Land Rover 2
LarryK Land Rover Repair or just plain how to! Rover / Land Rover 1
catfood Land Rover Evoque Convertible Spotted 1
aeronca65t Landwind - fake Rover Rover / Land Rover 3
Steve Land Rover 90 vs. Dodge Ram Rover / Land Rover 1
Boink First Range Rover Rover / Land Rover 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
K Land Rover Defender - Mountain Rescue Team Rover / Land Rover 0
N Land rover and coffman cartridge starter Rover / Land Rover 0
HealeyRick A Visit to the Land Rover Factory Rover / Land Rover 0
B Rover V-8 main bearings Rover / Land Rover 5
G Rover 3.9 info?? Rover / Land Rover 1
JPSmit Land Rover Defender - and Home made special Spotted 1
aeronca65t Rover car carrier Rover / Land Rover 1
JPSmit Land Rover - hopefully good news. Spotted 9
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
aeronca65t Churchill's Land Rover For Sale Rover / Land Rover 1
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
Steve New Land Rover Defender Rover / Land Rover 9
58Custom Rover V8 in SoCal self-serve junkyard Rover / Land Rover 0
