Rover V8 interchange/swap question
G
I'm thinking about picking up a Rover V8 engine for possible future use in a B. I talked to a guy who said the 4.0 had a longer crank snout and won't go into a B. He said the 3.9 and 4.2 will. I looked in the wiki and it said the 3.9 is the 4.0, just reffered to differently. What's the break down on these engines? What will swap to what and what will fit in a B? Thanks.
tr8todd
In a nut shell. The 3.5 and the 3.9 used the same crank. 3.9 had a larger bore. The 4.2 used the same bore as the 3.9 but a longer stroke crank. The 4.0 has the same bore and stroke as the earlier 3.9, but internally it is a much different engine. The 4.6 has the same bore as the 4.0 but a longer stroke crank. The later 4.0 and 4.6 are better engines because of the larger journal sizes on the crank and because the mains are cross bolted. For the most part, externals will bolt on and cross between the different engines. The later engines use a different cam and cam retainer, but can use the older cams. The crank snouts are different lengths. You need to run a spacer to make the older multi pulley balancer work on the newer cranks. The newer engines used a serpentine setup. Lots more subtle differences, so you will need to do some reading up before you get too deep into it. The expense in these engines is not in acquiring the engine, it's in acquiring all of the hard to find parts that bolt to it. The bolt ons that come out of the Range Rovers that the engines are sourced from are virtually useless in a sports car install. You will need to source proper fitting oil pan $300, timing cover $200, bell housing and shifter components $300, clutch $200, flywheel $200, intake and carb $500, headers $300, you see where I'm going.
G
What I need to know is which engine is the "right" one and which ones should be avoided. They have a 4.0 that looks to be in good condition and a 4.2 that's been setting a while.
JPSmit
Billy, stop this right now. You are trying to get rid of stuff, you don't have a B and when you do (if you do) you can get an engine then - now you will just have more cr*p.
:nonono:
G
Y'aint thinkin right JP.
If it's shot, I can melt it down into sculpture.
If it's good I may be able to use later OR, sell it and make a few dollars to keep the Midget going.
They are getting hrder to come by and hate to see it crushed.
It's sounding like the 302 w/ aluminum heads is an eaiser/cheaper option.
G
Is there any truth to the 4.0 and 4.6 crank snout being too long to fit in the B?
J Land Rover research Rover / Land Rover 4
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
F For Sale Rover V8 blocks for sale Other British Classifieds 1
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
CJRams For Sale 1996 Rover MGF 1.8i - $15,000 MG Classifieds 3
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
D Land Rover engine swop. Rover / Land Rover 1
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
A MGB Donor Rover 3500 P6B for my MGB MG 5
albertemore Range Rover Classic Parts? Rover / Land Rover 5
G Rover P3 Brake Lining - Front Rover / Land Rover 2
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
PAUL161 Land Rover 73 Rover / Land Rover 0
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
Steve Range Rover Evoque Convertible Rover / Land Rover 2
LarryK Land Rover Repair or just plain how to! Rover / Land Rover 1
catfood Land Rover Evoque Convertible Spotted 1
aeronca65t Landwind - fake Rover Rover / Land Rover 3
Steve Land Rover 90 vs. Dodge Ram Rover / Land Rover 1
Boink First Range Rover Rover / Land Rover 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
K Land Rover Defender - Mountain Rescue Team Rover / Land Rover 0
N Land rover and coffman cartridge starter Rover / Land Rover 0
HealeyRick A Visit to the Land Rover Factory Rover / Land Rover 0
B Rover V-8 main bearings Rover / Land Rover 5
G Rover 3.9 info?? Rover / Land Rover 1
JPSmit Land Rover Defender - and Home made special Spotted 1
aeronca65t Rover car carrier Rover / Land Rover 1
JPSmit Land Rover - hopefully good news. Spotted 9
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
aeronca65t Churchill's Land Rover For Sale Rover / Land Rover 1
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
Steve New Land Rover Defender Rover / Land Rover 9
58Custom Rover V8 in SoCal self-serve junkyard Rover / Land Rover 0
rosalind Bye Old Rover...Hello new Rover Rover / Land Rover 2
aeronca65t Land Rover Forward Control Rover / Land Rover 0
T What car could use a Rover V8 Other Cars 3
Got_All_4 Wedge Rover 3.9 in a Tr7 Triumph 34
Steve Range Rover Evoque Rover / Land Rover 1
AngliaGT Rover 3500 Rover / Land Rover 1
M 2000 range rover????? Other British Cars 1
D 1935 Rover 10 wiring dia. and head lamp solonoid.. Rover / Land Rover 2
weewillie rover p6 and nissan skyline Spotted 0
racingenglishcars Land Rover collection for sale - in Norway, Dec 4 Rover / Land Rover 0
S Looking for a Rover 215 motor. MG 9
JPSmit Rover for sale Other British Cars 4
J Rover engine that started as Buick? Rover / Land Rover 9
