100-4 front main bearing cap issue
WaltCasten
Hello all,
My BN2 is being restored and I am trying to re-gasket the engine while it is out. One issue I have run into is the front main bearing cap stands proud of the front surface of the block by .010". The rear one was flush. FYI, this engine was rebuilt back in the late 1970s. Anyway, it appears the engine was leaking from this area so I would like to address this somehow.
Is it possible to loosen the front main cap bolts and tap this back flush? Even if possible is this a bad idea? Should I just silicone this area and be done with it? It seems like one would want a nice flat surface for the front mounting plate to be bolted to.
Any help is appreciated.
Thanks,
Walt
Keoke
Yes I think as far as realigning the cap it can be done as you suggested, However, concerning the leak at this bearing I do not know how any sealant would help.-Fwiw--Keoke
BoyRacer
I don't see any problem with your solution - if it works. The main bearing caps usually fit so tight that there is not much run for movement. If it doesn't get flush, you could remove it and have it milled down. Silicone is really great stuff but If it was my engine I would want a flush fit.
W
WaltCasten
Well, loosening the nuts and tapping it back isn't an option. It appears there isn't enough clearance around the nut for the cap to move anywhere. There is a spot face where the nut bears, then a shroud of cast material around that area that wasn't machined. The apexes of the nut hit that shroud when you try to tap it back. You can move it back about .005" with the nuts loose, then as soon as you tighten them it goes right back to the .010".
I guess my only option to make it right is to either have a machine shop cut the .010" off the front or open up the spot face around the nut.
Keoke
Either one sounds like agood way to go .However, I like opening up the spot face the best.--Keoke
W
WaltCasten
The machine shop also suggested just putting a ground and hardened washer under the nut. They did not have an ARP washer with that big an ID, fortunately I have a Fastenal right across the parking lot from where I work so I went that route. There was a metric size that was really close, I had to open the ID up a little. I re-assembled, torqued it to 75 ft-lbs and the cap now sits flush.
It was also suggested to chuck the nuts up in a lathe and take a little off the apexes down at the bottom as the socket can't reach down there anyway because of the cast material (shroud around the spot face).
If anyone thinks the washer is a bad idea, let me know asap as I plan on buttoning this thing up tomorrow.
Thanks for all the input!
Later,
Walt
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
P 100/6 Front Wheel Alignment Austin Healey 10
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
L 100/6 replacement front seats Austin Healey 7
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
C 100-6 front drum brakes? Austin Healey 36
A Wanted Front Bumper Brackets/Spring bar assembly for 100-6 Austin Healey Classifieds 0
L Front Brake 100/6 Austin Healey 1
D front shocks 100 m Austin Healey 12
T Front transmission seal not on 100-6 Austin Healey 2
C AH 100 Best Options for front and rear suspension? Austin Healey 9
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
T 100 4 Front Sway Bar Austin Healey 12
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
Y Restoring a 58 100 six front shroud Austin Healey 1
R 100-4 front fender removal Austin Healey 2
T 100 Front Shroud Attachment Austin Healey 0
M Healey 100-4 Front Spring Stiffness Austin Healey 2
bighealeysource 100-4 front shock replacement Austin Healey 2
H Healey 100 Front Wheel Bearing replacement Austin Healey 4
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
S 100/4 front suspension/Mt Washington Hill Austin Healey 3
J Does anyone need a front valance for a 100-4? Austin Healey 1
mbrooks 100 oil leak from front of engine Austin Healey 3
Editor_Reid Healey 100 Front Springs Austin Healey 7
timbn2 Front Shroud for 100 Austin Healey 2
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
