100 4 Front Sway Bar
TonyR
I have a TR3 with a front sway bar ( anti roll bar) that is very stiff. It is a hoot to drive. Kas Kastner recommends a stiff front with a stock rear as the best combination.
My Healey BNI has the standard front bar that is very weak. Question is, which bar is recommended to stiffen the front?
Is the route to fit a 100M type bar or a bar from a 3000?
Cheers,
Tony
wangdango
We have a '56 100 LeMans vintage race car and use urethane bushings all around, a front bar from Victoria British (think they only sell one size), BJ8 front springs, front shocks with heavier valves and 40weight motorcycle fork oil in them. The rear is stock springs, shocks, fork oil weight. We were told by a lot of folks when we built the car (over 20 yrs ago now), make the front stiff and keep the back soft. The car handles fantastic, and with Dunlop Racing tires she slides in perfect 4 wheel slides......
Patrick67BJ8
Cheers,
Tony
I owned a 100 over 30 years ago and I installed a standard 3000 swaybar and it improved the handling.
My 7/8" front swaybar (stock 3/4"?) was purchased from Addco back around 1985. They probably still offer them.
I, at times, also used a 3/4" rear bar, but it's been off the car since I put the articulated A-arm on (instead of the Panhard Rod).
T
TonyR
Thanks guys,
I guess I was on the right track, I have purchased some up-rated valves and thicker oil for the front shocks.
I gain as much enjoyment out of playing with these cars as I do driving them!
Tony
WaltCasten
I don't think the stock 100 (4 cylinder) front bar was 3/4", more like 1/2" and some had 5/8".
Later,
Walt
big6
"I put the articulated A-arm on (instead of the Panhard Rod)".
Randy,
Can you post some photos?
Thanks...
Later,
Walt
Mine's a 100/6, but maybe 5/8" is closer__it's been decades since I've seen the original swaybar; it might be stored with some other Healey parts I have (including a couple of engines) in my brother's shed in Florida...
... I guess now that I'm moving to Florida, he'll want me to come get that stuff too!
Randy,
Thanks...
BoyRacer
Wangdango is spot on. Keep the front stiff and the back end soft. If you stiffen up the rear it will want to swap ends. I learned that when I installed a rear sway bar 25 years ago in my race car. At the time it sounded like it was the next smart move to make the car handle better -- big mistake for a big Healey.
Now, you can do this on a street car and maybe never realize the mistake you made because you don't drive it hard enough. Because I drive my car at the absolute limit every time I race, I know what works and what doesn't.
I use a 1" sway bar in front and 500 lb front springs. BJ8 springs are about 385 lbs. No rear sway bar. Stock rear springs with the smallest leaf removed. Very soft rear shock setting (I have adjustable Armstrong rear shocks) Traction bars to prevent spring windup - it acts something like a 4 link setup - very effective. I use the stock panhard rod with urethane bushings at one end and rubber bushings at the other (you do need some flex).
In my opinion, for a 6 cyl. street car, I would go with BJ8 front springs and go with a 3/4" front sway bar with (of course) urethane blocks. The most important thing about the higher rated BJ8 springs is that they eliminate a lot of body roll when cornering.
My stock BJ8 sway bar is 3/4". I installed a 7/8" bar from Addco:
https://02bbfb5.netsolhost.com/aftermarket.htm
To the best of my (amateur) observations, the car stays flatter in corners with no discernible increase in understeer. I did have to notch the bumper brackets to make room for the bar.
Can't say enough good stuff about Addco.
BoyRacer
That's odd, I had a BJ8 once and I thought the sway bar was the same as the earlier 3000s - 5/8".
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
P 100/6 Front Wheel Alignment Austin Healey 10
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
L 100/6 replacement front seats Austin Healey 7
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
C 100-6 front drum brakes? Austin Healey 36
A Wanted Front Bumper Brackets/Spring bar assembly for 100-6 Austin Healey Classifieds 0
L Front Brake 100/6 Austin Healey 1
D front shocks 100 m Austin Healey 12
T Front transmission seal not on 100-6 Austin Healey 2
C AH 100 Best Options for front and rear suspension? Austin Healey 9
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
W 100-4 front main bearing cap issue Austin Healey 5
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
Y Restoring a 58 100 six front shroud Austin Healey 1
R 100-4 front fender removal Austin Healey 2
T 100 Front Shroud Attachment Austin Healey 0
M Healey 100-4 Front Spring Stiffness Austin Healey 2
bighealeysource 100-4 front shock replacement Austin Healey 2
H Healey 100 Front Wheel Bearing replacement Austin Healey 4
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
S 100/4 front suspension/Mt Washington Hill Austin Healey 3
J Does anyone need a front valance for a 100-4? Austin Healey 1
mbrooks 100 oil leak from front of engine Austin Healey 3
Editor_Reid Healey 100 Front Springs Austin Healey 7
timbn2 Front Shroud for 100 Austin Healey 2
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 8
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
