Removing front shocks on a 100 -4
bighealeysource
Bronze
Hey all,
I'm needing to replace the front shocks on my 54 100 -4
and thought I would ask this esteemed group for their advice.
I've looked at a 100 -4 repair manual and does not exactly
deal with removing them. Have replaced front shocks on
other Brit cars but not a Healey. Do I have to compress
the front springs and other fun things or is this pretty
much just unbolting and removing the top wishbone bolt/s ?
Appreciate any advice or warnings so I don't get in over my
head.
Thanks,
Mike
The shock, on full droop does indeed still allow plenty of stored energy to stay in the spring.
How I've been doing it, is with the car safely on jackstands, put a raised floor jack under the side of the front suspension I wish to remove. After pulling out the upper trunion pivot pin, I then lower the jack releasing the spring. Now all that's left is to remove the four (4) shock mounting bolts.
Assembly being the opposite order of things.
Please have respect for those springs!
An alternative method, which I've also used, is to replace the springpan mounting bolts one at a time with a six inch (6") length of AllThread. With this, then you can slowly and evenly open the distance between the lower A-arms and the spring pan releasing the energy in the spring.
Again, BE CAREFUL!
John Turney
Again, BE CAREFUL!
I'll repeat it: BE CAREFUL of those springs!
I've used the all-thread method, and so far I have all of my pieces still together.
healeynut
Mike -
If you put a jack in the spring cup under the wishbone and jack it up, you'll be able to remove the shock without removing the springs. It's a good idea to put some large wood blocks under the chassis just in case the car comes off the jack, but I've never had that happen so it should be ok.
Be prepared to heat the bushes a bit to get it all apart, the link bolts usually get corroded into the bush crush tubes.
Dougal
Not sure about the jack method, i'm always very wary around those springs,its to easy to lose a finger or your teeth or worse if one "escapes".
The manual states that the best way if you don't have the special tool is to use the long bolt method described above. I have found this very simple and safe. You need a couple of 6inch lengths of high tensile 3/8 studding. I welded a nut on one end of each, that way you can't accidentally unscrew it off the end while the spring is still compressed.
Remove one of the bolts holding the lower wishbone arm to the spring pan and replace it with the studding, secure the studding by screwing down a second nut from the other end. Do the same with the diagonally opposite bolt. Next remove the remaining two bolts. Now just wind down the un-welded nuts equally and the spring pan will be pushed down as the spring extends. Reassembly is the reverse of the above.
Oh and you may want to look carefully at the threads holding the shock absorber on , they get a lot of abuse and often have a mixture of BSF and UNF bolts in them. If I can work out how I will put a link to a previous post that you may find interesting.
Here you go https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/514130/1
zblu
bighealeysource,
I used the threaded rod method as described by others above, except I used longer rod and left any nuts unwelded, but pretty much the procedure as described by Dougal
glemon
I normally would be wary of using a jack, but the lifting cup on a floor jack fits pretty much perfectly into the spring cup at the bottom of the A-arm--at least mine did, making for a very secure fit (i.e. can't slide off).
mjobrien
I have used the below method as well with good luck. My main concern with jacks is that if things are off balance a little you can have something slip and these springs to have a lot of energy in them.
"An alternative method, which I've also used, is to replace the springpan mounting bolts one at a time with a six inch (6") length of AllThread. With this, then you can slowly and evenly open the distance between the lower A-arms and the spring pan releasing the energy in the spring."
Take your time, these things can hurt you if you rush.....
Michael.
55 BN1
bighealeysource
bighealeysource
Bronze
Hey Y'all,
Thanks so much for the advice ! I've got the 100-4 up on 4 jack stands so
it's very secure in that respect. Will check and see how my floor jack's
lift cup fits under the spring cup. If it is not a good fit, I'm heading
to Home Depot to buy the 3/8 inch threaded rod as I do not want a Healey
shock deciding to make me a gelding or worse!
Regards,
Mike
bighealeysource
bighealeysource
Bronze
Hey Alan,
Thanks for your advice. Like I said in my general reply
I'll see how my floor jack fits with the bottom of the
spring cup. Question for you, if I jack up/compress the spring
with the floor jack, then I can simply ( what is ever simple
on a 54 year old car) unbolt the shock and remove it ?
Obviously leave the jack in place and place the new shock
in place, bolt it down, and then release the jack ?
Thanks for your further help.
Mike
bighealeysource said:
Hey Alan,
Mike
Answering for Alan :wink: Yes.
Since you're only replacing the shock(s), the jack would be the preferred method, in my opinion.
If you decide to use the "allthread method," cut the rods at 6 inches. Screw down the nuts an equal distance on top and bottom, then use a deep socket with an air ratchet to un/screw the nuts. Otherwise, it's a tedious task to unscrew the nuts with an end wrench a couple turns at a time (I've only seen 3/8" allthread available in fine thread).
healeynut
Mike -
I know it's safer to compress the springs or lower the spring cup, but the jack method works just fine. The main thing is just putting some big wood blocks under the chassis just in case it all goes hairy.
When you jack it up this way, be prepared that the spring will decompress a little as the lever arm length will move from the wheel to the jack.
I would also highly recommend using a decent floor jack to jack up this way, as this will drastically reduce the chance of the car slipping off the jack while you are working on the shock. Do not use any sort of bottle, scissors or shelly jack as you will have some risk of it toppling - removing the bolt from the upper link bushings can be a knuckle dragger's process.
B TR2/3/3A Removing front trunnion Triumph 15
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
KVH TR4/4A Removing Front Transmission Seal Triumph 1
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
catfood Removing front hub Austin Healey 6
drooartz MGB-GT Question - removing front bearings MG 2
S Problem removing front wheel bearing retaining nut Austin Healey 9
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
J TR2/3/3A Removing front spring pans? Triumph 6
T Question on removing drivers front lower wishbone Triumph 7
B TR2/3/3A Tr3 removing front wings Triumph 8
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
G Advice needed in removing front left fender. Triumph 2
A removing front apron Triumph 10
T TR4/4A Removing TR4a front rotors Triumph 5
Number_6 TR2/3/3A Removing front fenders on a TR3 Triumph 20
J Removing front bonnet - MKII Austin Healey? Austin Healey 4
kennypinkerton removing front crossmember... MG 13
N Removing Front fender MG 4
DanZ_BT7 removing the front discs Austin Healey 4
T Removing front fenders & hood Triumph 10
HAN8L1965 Removing Front Springs 65 Sprite Spridgets 1
J Removing top fulcrum pin on front suspension. Austin Healey 2
A Spitfire Removing cap over front hub on Spit Triumph 2
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
