100-4 front shock replacement
bighealeysource
Bronze
Hey all,
I got great advice on how to handle taking off the old
front shocks on my 100-4 - used the floor jack under the
spring system which worked great. However, HOW DO YOU
COMPRESS THE TOP LINK BUSH DOWN to get the fulcrum pin
into place ????? Any help will be greatly appreciated.
Thanks,
Mike
bighealeysource said:
Hey all,
Thanks,
Mike
Take out the bolt holding the two arms together and drive a wedge between them. You should get the clearance you need.
Mentioned that in the PM...
bighealeysource
bighealeysource
Bronze
Ooh rah ! Knew someone would come to my rescue. Just got the new rebuilt shocks
back from Apple and will take that bolt off and spread the arms to get that extra
1/8 inch per side so I can get the thing back on ! Thanks Randy.
Regards,
Mike
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
P 100/6 Front Wheel Alignment Austin Healey 10
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
L 100/6 replacement front seats Austin Healey 7
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
C 100-6 front drum brakes? Austin Healey 36
A Wanted Front Bumper Brackets/Spring bar assembly for 100-6 Austin Healey Classifieds 0
L Front Brake 100/6 Austin Healey 1
D front shocks 100 m Austin Healey 12
T Front transmission seal not on 100-6 Austin Healey 2
C AH 100 Best Options for front and rear suspension? Austin Healey 9
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
T 100 4 Front Sway Bar Austin Healey 12
W 100-4 front main bearing cap issue Austin Healey 5
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
Y Restoring a 58 100 six front shroud Austin Healey 1
R 100-4 front fender removal Austin Healey 2
T 100 Front Shroud Attachment Austin Healey 0
M Healey 100-4 Front Spring Stiffness Austin Healey 2
H Healey 100 Front Wheel Bearing replacement Austin Healey 4
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
S 100/4 front suspension/Mt Washington Hill Austin Healey 3
J Does anyone need a front valance for a 100-4? Austin Healey 1
mbrooks 100 oil leak from front of engine Austin Healey 3
Editor_Reid Healey 100 Front Springs Austin Healey 7
timbn2 Front Shroud for 100 Austin Healey 2
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 8
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
