Main Bearing Replacement
Stretch
As part of the plan to continue improving my car I've contemplated replacing the engine main bearings from time to time. The manual says the crankshaft has to be removed which requires removal of the engine. Does anyone know a way to remove the bearings without removing the engine? For instance can the upper half of a bearing shell be rotated out with the crankshaft in place?
Dave Russell
Yoda - R.I.P
Stretch,
You might be able to replace the main bearings without removing the crank but it would be pretty difficult. Then there is the center main thrust bearings to deal with.
Why do you want to replace just the bearings? Chances that if the mains are worn enough to cause trouble the rod & cam bearings & most everything else including piston rings needs replacing also.
Unless there are extenuating circumstances, I think that it would be a waste of time to just replace bearings & the chances of screwing something up are great.
If the engine is that bad, it needs to be pulled & rebuilt. If not that bad, just live with it for a while.
S
Stretch
Engine is not bad but oil presssure is on low side. Last winter I rebuilt the rocker arm assembly with no improvement in oil pressure. I've just been making improvements in stages and really don't want to pull the engine right now. Bottom line is I like to tinker.
Dave Russell
Yoda - R.I.P
Stretch,
OK, give it a try. Should be an interesting experiment. Be sure to do the rod bearings also. Then the only remaining cause of low pressure would be the cam bearings.
I have done things like this in the "distant" past. If you can't get all of the main shells out just replace as many as you can. Anything will help some. I wouldn't expect 50,000 miles more out of it but you never know.
As far as performance & reliability, it will depend a lot on how good & how even the compression is now.
Have fun,
ThomP
The other thing you might consider before replacing the mains is the oil pump. When I rebuilt my engine, the oil pump "looked" good upon inspection, so I didn't replace it. After I fired the engine, I had oil pressure, just not good oil pressure (~20 lbs at idle and 35-40 lbs at speed). This worried me, because the engine was new, so I replaced the oil pump. The difference was dramatic: ~30-35 lbs at idle and 50-60 lbs at speed.
It's also easier to replace than the mains and it just may be your culprit. Happy tinkering.
piman
Hello Stretch,
there is a little trick to removing main bearing shells which is to put a split pin into the journal oil drilling and rotate the crank pushing the shell out (from the non tab side obviously).
Alec
Bob Claffie
I'd vote for the pump, too. The main bearings are the first thing in the engine to get oil and the last to fail. If not the pump try something simpler like the rod bearings. Anyway, what's the point of slipping in new mains without measuring the journals! Bob
S
Stretch
I appreciate the tips. I have a friend who races sprint cars. He's replaced main bearings in his race engine in the manner discussed without pulling the crankshaft. I believe the journals can also be measured for wear so I can do the proper checks, but just replacing the bearing will still regain some clearance lost to wear. The oil pump intrigues me more, though, now that two people have mentioned it. Looks like parts are available. Has anyone rebuilt one of these with good success?
Pete Haburt
Stretch;
I replaced the oil pump gears in my 61 BT7 as mine were scored, and it made a huge difference.
Added 15lbs at idle and at cruising(hot). I now have 38psi idle, 58psi above around 2500 rpm.
Pete H.
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
J General TR Main bearing caps Triumph 6
R Main Bearing Cap Removal Austin Healey 12
D BT7 main bearing seals Austin Healey 11
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
A 100 engine main bearing cap nut question Austin Healey 0
oxford main bearing caps Austin Healey 4
M Healey 100-4 NOS Main Bearing Concerns Austin Healey 3
W 100-4 front main bearing cap issue Austin Healey 5
G TR6 TR6 main bearing torque Triumph 7
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
rikiwho123 Main Bearing Cap Bolts Triumph 6
F Main / Rod bearing sizes. Spridgets 6
M Main Bearing Cap Question Spridgets 2
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
Bruce_B Locktabs on Main Bearing Bolts? Spridgets 3
healeynut Main Bearing Caps - 100 Austin Healey 7
vping Main bearing cap puller Restoration & Tools 0
J Main Bearing Seal Leaking Spridgets 19
B Main Bearing on 3000 Austin Healey 3
T .050" main bearing source MG 1
S Main Bearing caps Austin Healey 4
S Main bearing thrust washer ? Spridgets 3
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
