General TR Main bearing caps
James A Martin
I ruined the middle main bearing cap in my 2138 cc TR3B engine. I cant find a price for a new one on any of the usual parts vendors.
Has anyone got a ballpark for used caps? I found some used and the seller wants an offer.
I dont think I want to use this. But it may be OK as no material is missing fron a contact surface either on the thrust bearing or main bearing sufaces.
I think the reason you don't see the caps offered at vendors is because it is not as simple as just replacing a part. I believe the block and caps were lined bored when the engine was built, thus a cap is unique to the engine it was fitted to, a cap from another engine will differ slightly.
Geo is exactly right. You will have to find a replacement used cap and then have the entire block line bored. You are looking at $200+ for the machining plus the price of the cap. A used block will likely be cheaper.
Question, though. Is there enough metal left to prevent the thrust bearing from spinning? if so, use what you have. If not...we can think for a while about a way to stabilize the thrust bearing as a way of keeping your engine block.
Like having the washer pinned to the cap. This is a common racing modification for Spitfire and TR6, and a lot cheaper than line boring.
Randall,
I contacted Scott, site looks real nice, no reply yet, I'll let ya know, CNC? $$$.
I'm off to the machine shop with new valves, guides, old crank and block, the head is already there. I'll ask them about pinning the one thrust washer to the cap, and hope their eyes dont glaze over......
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
oxford main bearing caps Austin Healey 4
healeynut Main Bearing Caps - 100 Austin Healey 7
S Main Bearing caps Austin Healey 4
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
R Main Bearing Cap Removal Austin Healey 12
D BT7 main bearing seals Austin Healey 11
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
A 100 engine main bearing cap nut question Austin Healey 0
M Healey 100-4 NOS Main Bearing Concerns Austin Healey 3
W 100-4 front main bearing cap issue Austin Healey 5
G TR6 TR6 main bearing torque Triumph 7
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
rikiwho123 Main Bearing Cap Bolts Triumph 6
F Main / Rod bearing sizes. Spridgets 6
M Main Bearing Cap Question Spridgets 2
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
Bruce_B Locktabs on Main Bearing Bolts? Spridgets 3
vping Main bearing cap puller Restoration & Tools 0
J Main Bearing Seal Leaking Spridgets 19
B Main Bearing on 3000 Austin Healey 3
T .050" main bearing source MG 1
S Main bearing thrust washer ? Spridgets 3
S Main Bearing Replacement Austin Healey 8
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 13
Gerard 1098 10CC rear main seal conversion Spridgets 4
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
