sjuengst
Recently, I put the car up on jackstands to change the transmission and differential oil. I noticed that the brakes were dragging on the passenger's side rear wheel. I decided to take the wheel off to get to the brake adjuster screw. Since it was such a PITA getting this low-slung car up on jackstands, I knocked off the hub while in the air, using one of those wooden knock-off wrench/dog-ear things. That all went smoothly, but a couple of days later I noticed gear oil leaking from the brake drum. Closer inspection shows it coming from between the axle shaft and hub.
It wasn't leaking before ... is it possible that I damaged the oil seal by hammering on the knockoff while the wheel was unsupported?
In any case, I've ordered a new oil seal and gaskets. Are there any special tricks to installing them? Is the oil seal a press-fit, or will I be able to install it by hand?
Thanks,
stu
Thanks,
stu
