Gear Grinding in my BJ8
shorn
Lately I would experience some grinding when attempting to shift into first or reverse gears in my BJ8. Yes, the car was completely stopped. At first I thought there might be some air trapped in the clutch hydraulic line, master or slave cylinder. After a couple of attempts at bleeding the system, the occasional grinding remained. Although it did not appear to be losing any fluid, I looked under the dash to inspect the master cylinder push rod. It was then that I noticed that there was a little sloppiness in the clutch pedal. I removed the clevis pin and noted that it was significantly worn. Installing a new clevis pin seems to have eliminated the grinding. I guess the sloppiness kept the clutch from totally disengaging the engine. I wish I had changed the clevis pin before the bleeding the slave cylinder. That was a bear to get at.
Skip,
You can restore the push rod through holes by welding on some appropriately sized washers on each side and then do a bit of grinding to get close to original looking. Or you can just weld up the sloppyness and rebore (helps to have a mill and big vise to bore the new hole cleanly). Sure makes the clutch feel like new again to get rid of the slop.
Cheers,
John
Hello shorn, John is right when he says it makes the clutch feel like new again fixing the worn holes. What i did on my BN7 was to drill out the holes in the clevis and the pedal and press in some spacers then ream them in place back to original size. The other thing i do is when going into 1st gear make sure you go into 2nd gear before, as this will stop the gears rotating in the gearbox, making it easier to select 1st. Also the same goes for going into Reverse, select 3rd or 4th then go into reverse. Regards, BUNDYRUM.
J Clutch and Grinding Gear Austin Healey 12
K Second gear grinding Triumph 17
BierRunner TR6 Gear Shift Knob Challenges Triumph 5
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
Joe Reed MGB Dropping out of 3rd gear... MG 2
J Planetary Gear Removal Austin Healey 3
