Hi All,
Steve, by its original described operation, I wonder if your inertia switch was meant to establish an emergency lighting response i.e. trigger the flashers?
I scavenged 2 inertia switched from the the boot side compartments of 2 junk-yard resident late '70s (I think) Ford sedans at least 15-years ago and installed one in my Healey and the other in my Triumph TR7. I mounted each on the frame rear bumper support inside the boot of the car (left side on the Healey) and wired them to disable the pumps in case of an accident (substantial jarring). Since the units are hidden, simply hitting the units directly will also disconnect the pumps and act as an incognito anti-theft device.
Although wiring your units under the dash may result in the disabling of the pump in the case of an accident, I would make sure the mounting is not shock resisting and the unit receives sufficient shock to cause it to respond in an accident.
Ray(64BJ8P1)
