TR2/3/3A TR 3A Rear Lug bolts
RonR
Folks.
Does anyoen have any suggestions on how to remove the threaded rear wheel lug bolts on a TR3?
I am going back to the original steel wheels and the existing lug bolts have been cut off to accomodate wire wheels.
Thanks.
Ron
karls59tr
Bronze
Find two smaller nuts of the same thread that will fit on to the bolt. Tighten them together then put the wrench on the bottom bolt and back the bolt out. Maybe squirt some penetrating oil on the bolts to free them up.
TR3driver
Great Pumpkin - R.I.P
Ends are definitely peened, and must be ground off. Sometimes it's easier to repeat several times, ie grind as much as you can without damaging the hub, back the studs out as far as they will turn, then screw them back in and grind some more. That way you get some room to grind the stud away without cutting into the hub. The hub will crush the peened area inwards.
Thread is 7/16-20 UNF. With persistence it can be done on the car, but my preference is to pull the axles out. That unfortunately means you will need new lock tabs. Might also be a good time to change the inner oil seals if they show any signs of letting gear oil into the bearing grease. Don't try to separate the hubs from the shafts, though.
Since the old studs are ruined anyway (cannot be reused once removed), you can just grab them with Vice Grips if you want. I've even been known to use a pipe wrench.
NutmegCT
Just a thought - if you're going back to the original steel wheels, check them for bending. Over the years, bumps and curbs can bend the wheel. It's tough to re-shape steel, so it usually can't be returned to true. Usual symptom: wobbling at speed, like an out of balance tire. Check by mounting the wheel, touch your finger to the side of the rim, slowly turn the wheel, and see if the rim moves "in and out" from your fingertip.
Tom M.
Geo Hahn
All this removal advice raises the question -- what is the best method for securing the new studs with the hub still in situ?
Seems like peening (at least that whopping great mash of peening the originals have) would not be practical. Lesser peening from the side? Loctite? Spot weld?
CJD
I'm sure there are a lot of options. I'd be inclined to clean it well and then locktite them. I'd torque about 15% higher than normal...and they'll stay.
PeterK
I did mine off the car but I used a dull cold chisel and made a star-shaped peen by turning the chisel between each whack. This is after the threaded were full home with double nuts.
M removel - rear axle lug studs Triumph 7
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
