    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
removel - rear axle lug studs
midnight
Any suggestion for removing lug bold studs from rear axle flanges - other than pulling axles and pressing out studs - mid-night
For a TR3A they don't press out - they are threaded in and peened over on the back side. They are a pain..
:iagree:
O.K. - I have a problem !!!!! The studs on my front wheels are pressed-in - I have replaced these - the conversion kit for spoke wheels (Victoria British) supplied 16 press-in studs - so, I "ASSUMED", wrongly, as it turns-out, that all four wheels were the same - I have used a mirror to inspect the backsides - I see no penning marks - If they are there, I see no way to replace these without pulling the axles - I tried double nutting a stud - got no movement - AUTO RESTORATION - OH FOR THE JOY - Beer, so much more than a breakfast drink - mid-night
If the studs on the car are too long, just install the wire wheel adapters, and cut off the excess. I believe that is a factory-recommended procedure.
I agree- or in my opinion, buy 1/4" spacers and keep the studs as is. You won't notice the difference with the wheels installed, and you can go back to steel/alloy rims if you want.
They aren't so much peened but swaged -- sort of mushroomed over very neatly so it can be hard to tell what they did.
As I understand it the usual method (haven't had to do it) is to remove most of the swaged material (using Dremel or angle grinder) then withdraw -- the remaining material will then flare up and more removal until finally it's free.
Me? I used the spacers. Let's me switch back to disc or alloy wheels from time to time:
Thanks to all - If the factory is cool with trimming the studs to length - it's works for me - the spacer is a good idea too - mid-night - BEER, so much more than a breakfast drink -
T TR2/3/3A tr3a verticle link removel question Triumph 11
J Brake pedal cover removel? Triumph 5
bluemiata90 TR2/3/3A TR3 Horn,control head and stator tube removel Triumph 9
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
