TR6 Thrust face repair
This would, I think ,involve welding and line boring. It would be $$. Only an extraordinary
machine shop would be able to do it. Unless it is a numbers matching motor ,it is scrap.
Mad dog
KVH General Tech Thrust Washers Triumph 2
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
B TR4/4A Thrust washer issue Triumph 11
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
JPSmit Midget Thrust bearing coonversion Spridgets 9
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
K Thrust washer Austin Healey 4
J TR6 Thrust washers in sump Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
PeterK Wedge TR7 thrust washer Triumph 0
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
H 4.2L distribitor drive distance/thrust washer Jaguar 0
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
P those infernal thrust washers Triumph 11
H Crankshaft Thrust Washers Austin Healey 2
O Spitfire Spit 1500 Thrust Washers? Triumph 13
6 thrust washers & cam Triumph 7
Monark192 MGB MGB Diff Thrust Washer Question MG 2
S Tachometer thrust button Austin Healey 1
T ever see a rusty thrust washer? Triumph 10
T crank thrust bearings Triumph 5
TR6oldtimer TR6 Worn Thrust Bearings TR6 Triumph 26
K TR2/3/3A TR3 thrust washers wishbone arm to trunnion ? Triumph 6
Jim_Gruber Wheel Bearings and Thrust Label Spridgets 6
healeyboz replacing a thrust bushing Spridgets 6
M pining the thrust washers on 1500cc Spridgets 10
M Layshaft thrust washer dimensions MG 1
B 1500 thrust washer Spridgets 10
Brosky Thrust washers, via Scott Helms and my way Triumph 8
JPSmit 1500 thrust bearing question Spridgets 10
2wrench Checking the thrust washers.....Dale? Triumph 3
Brosky TR6 Serious Thrust Washers for TR6 Triumph 24
Moseso Thrust Washer Dimension Question Triumph 3
B Sealing block and good thrust washers Triumph 5
2wrench Let's talk about the dreaded thrust washer wear. Triumph 8
B Pinning 1500 Thrust Washer Spridgets 3
Brosky Thrust Bearing Issue Triumph 22
floyd TR6 75 tr6 thrust washers Triumph 18
guzzul When thrust washers go bad Triumph 11
tomshobby thrust bearings Triumph 1
hondo402000 TR6 TR6 thrust washer question Triumph 3
hondo402000 TR6 Triumph TR6 thrust washers Triumph 2
B thrust washers Triumph 5
T Thrust Washers for Crypty Triumph 34
Tinkerman TR2/3/3A Crankshaft thrust washers, 60 TR3 Triumph 6
davidk Thrust Washer Questions Triumph 3
kaz2be Thrust washers Triumph 6
sparkydave Uh oh, not the dreaded 1500 thrust washer... Spridgets 14
jerrybny Thrust Washer Question Triumph 3
