1500 thrust bearing question
JPSmit
well, it's all apart - and I have the new thrust bearing ready to go - any tricks to getting the old one off? and the new one on? At this point, all I'm imagining is the appropriate sized big socket and a vice
Joelb
It's been awhile, but I think I had to take the arm off in order to get the bearing out. If you do that, replace the bushings holding the arm pin in when you put it back together.
JPSmit
JPSmit
the arm is off and the whole thrust unit is off the arm - now I need to get the sleeve off the bearing - or more accurately the bearing off the sleeve
aeronca65t
Are you guys talking about the <span style="font-weight: bold">engine</span> thrust washers? What is an "arm pin"?
Anway, if you are looking for some decent info on the engine thrust washers, here's two sites with some pictures and text.
https://www.teglerizer.com/triumphstuff/thrustwashers.htm
https://www.eighmy.com/spitfire/
Also, here's a decent text explaination of the process that I copied from an old website:
<span style="font-style: italic">The thrust washers are two semi-circular metal pieces that fit over the crankshaft on either side of the upper half of the rear main crankshaft bearing. They are held up into a groove in the block by the bearing cap, and cannot be seen with the rear bearing cap in place - unless of course they have fallen out due to wear and are lying in the bottom of the oil pan. While they are doing their job, they ride against flanges on the crankshaft preventing it from moving forward or backward more than the specified amount.
Remove the two 5/8" bolts of the rear crankshaft main bearing cap. Wiggle the bearing cap straight down. If it sticks, there is a threaded hole in the bottom centre where you can screw in a bolt finger-tight to act as a handle. Put the cap aside in a clean place for later inspection.
Assuming the thrust washers are still in place, pry the crankshaft fully forward, then use a small pointed tool or stiff wire to push up on one end of the front washer. It will be easier to remove the front one first because the front flange face of the crankshaft will still be flat. The washer will rotate around the crankshaft and drop out on the floor. Push or pry the crankshaft fully back, and push our the rear washer.
Check the crankshaft flanges for wear. The rear one will be likely worn most. If it is still smooth with no bits of thrust washer metal seared onto it, all is well.
Slip a new thrust washer into the rear position. Push the crankshaft forward and slip a new washer in the forward position. Washers come in standard thickness, and .005" and .015" oversize (ie thicker). Pick a combination of these to allow the crankshaft the specified endfloat. Checking this endfloat can be done in two ways. The simplest is to push the crankshaft fully forward, and use feeler guages to determine the space betwen the front washer and the crankshaft flange. Make sure the washers are up where they will be when the bearing cap is replaced. The second method involves using a dial guage clamped to the motor block. With the crankshaft pushed fully one way (back or forward) set the dial guage against a bearing journal or counterweight and zero the dial. Push the crankshaft fully the other way and read the guage - it should be between the 6 and 14 thousandths of an inch. If it is, your work is done.</span>
JPSmit
JPSmit
I could have used that description a few months ago! But, no, Nial, I'm talking about the thrust - now as I look at Moss - also called the release bearing for the clutch.
Specifically, I am wondering how to take the old bearing (12) off (13) and then put the new one on.
And, while we're at it, the Bentley book says I need to soak all parts in brake fluid before reassembling - does this still hold true?
Thanks all - and sorry for the confusion.
jcatnite
I just knocked mine off and tapped the new one on. Didn't present a great problem. It was harder to get the carrier apart from the arm than it was to get the bearing off the carrier.
JC
aeronca65t
Oh, the throwout bearing.....I see.
Yeah, like jcatnite says, it should just tap out pretty easily.
I'm not familiar with the idea of washing the throwout mechanism in brake fluid...I just wiped the crud off mine and reassembled.
JPSmit
JPSmit
that's why I love these boards so much - others bring clarity - I bring confusion
thanks though - hope to do it tomorrow - no steam tonight
Scott_Hower
Slighyly off-topic, but has anyone pinned their thrust washers so they don't fall out? I've heard this is common, but dont have a clue.
I dont seem to have any endfloat when depressing the clutch (Spit 1500), but want to do this once when I undertake the rebuild.
blkcorvair
If the thrust washers never fell out before or damaged the cap or block than you may want to just replace them with the solid bronze ones from Scott Helms. Do a google search, I used two of these in mine and they have much more contact area as well they are solid bronze through out so ideally they are supposed to last much longer. Just put them in mine. Satisfied so far. He also has some pics of pinned thrust washers on his homepage.
O Spitfire Spit 1500 Thrust Washers? Triumph 13
B 1500 thrust washer Spridgets 10
B Pinning 1500 Thrust Washer Spridgets 3
sparkydave Uh oh, not the dreaded 1500 thrust washer... Spridgets 14
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
