I did use those solid bronze washers once, no great advantage. You can pin em as well. Truth is the stock ones are okay so long as the crank is not all mushed up in the back. You can "pin" them but that takes a machine shop. Get yourself a magnetic dial indicator gauge and you will need to adjust the end float. The front bearing should remain stock size and change the rear to make up the slack. You can go .005, .010, or .015 over. Basically I recommend buying all three and fitting the largest that will squeeze in. I actually forced a .010 over bearing in mine by shaving the back (Steel) Side down on a bench with some sand paper. The .005 was just too loose to my liking. When installed I had .002 Clearance which is about as tight as you want to get. The books say .002-.007 is acceptable. But mind you as soon as it seats against the crank it will open that gap so I like to set em to .002 every time.
