4.2L distribitor drive distance/thrust washer
Hotdoc
Member
Hi
I'm rebuilding a'68 OTS Ser. 1.5 4.2 l and my problem is the Dis.drive distance washer.The book says there should be 4-6thou gap(?same as end float)
I'm reading around 20 thou. and there is visible movement.The adjacent bushing and drive gear don't show any wear 'tho the washer does .It is 0.117-8 thick and the shaft shoulder projects around 0.13-4th.The book seems quite concerned about too small a gap and I've had contact from someone whose drive seized at 4thou.My expert advice is that it's safe to just put it back together and the upper shaft will stablise it.Any thoughts?This item is discontinued by the usuals and I don't know where else to look
Cheers
Duncan Paterson
M TR2/3/3A HVDA Speedometer Drive Triumph 10
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
B MGA Tach drive issue MG 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
3798j Off Topic MGB at the Drive in Bank MG 1
Popeye General Tech O/D right angle drive choices Triumph 10
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
AngliaGT Mixture of Cars on My Drive Today Spotted 8
drooartz MGB First drive of the year! MG 5
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
DocDup1 MGB SpeedBox Speedometer Drive MG 0
tr6nitjulius General TR All TRIUMPH Only Drive In 2022 Triumph 4
BritBite Speedometer Right Angle Drive Austin Healey 5
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AngliaGT On Today's Drive Spotted 0
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
Zitch Engine Oil Leak After Long Drive Austin Healey 19
D T-Series Shorrock supercharger drive belt MG 7
tr6nitjulius General TR Sir John Black Drive Your TRIUMPH Day 2/10/22 Triumph 0
D Off Topic Remember to drive your Triumph Triumph 3
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
R TR6 Drive shaft orientation Triumph 3
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
KVH General Tech Angle Drive Broke (Repost) Triumph 0
KVH General Tech Angle Drive Came Apart Triumph 10
R TR6 1973 Final drive issues Triumph 5
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
F 1954 MG TF for sale, ready to drive and show MG Classifieds 1
C Bugeye propeller/drive shaft- universal joint Spridgets 1
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
nichola TR6 Oil pump drive barely engages Triumph 2
T Angle Drive Lubrication Austin Healey 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
L TR2/3/3A Drive shaft question Triumph 5
Lin Tach drive housing for BT7 Austin Healey 4
4tecdog Speedo drive gear Spridgets 15
RJS TR4/4A Speedometer and Angle Drive Triumph 6
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
mctriumph Morgan drive line Other British Cars 2
S Speedometer Angle Drive Austin Healey 2
D It's enough to drive ya to drink.... Jaguar 4
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
Healey Nut Mechanical tach drive Austin Healey 2
tr6nitjulius General TR Triumph Club of So Cal Spring Drive 4/27/19 Triumph 0
