TR2/3/3A HVDA Speedometer Drive
mastaphixa
Bronze
My 58 TR3a has an HVDA transmission fitted. My speedometer needle bounces all over the place when hooked to the transmission. I use a Toyota 90 degree adapter and the HVDA speedometer cable that came in the kit. My speedometer was mechanically overhauled by West Valley Instruments. Trouble shooting this problem I removed the 90 degree adapter from the transmission and the speedometer cable from the 90 adapter and spun the cable drive with my battery drill. The needle moved smoothly and to what ever speed I desired by modulating the drill speed, no bouncing at all. I then reattached the 90 adapter and did the same, once again the needle was steady as a rock at what ever speed I wanted. I was really surprised at this result. To me it clears the instrument, the speedo cable and the 90 degree adapter, but that only leaves an issue with the speedo drive gear in the transmission. Has anyone else experienced this? If I pull the speedo drive gear out of the gearbox will it dump the lube?
bammons
I don't have a answer but will be watching this. My speedo seemed to "slow" down above 60MPH and then just quit altogether. I thought it was the cable (HVDA setup) but I unhitched it from the speedo and it still turned when I drove it so it must be the speedo (prior to the restoration it worked fine). I did not use the 90* adapter. While it worked it was bouncy. Bruce
charleyf
I believe that there is a seal as a part of the internal part of the speedo drive. So I would guess that you could drip some oil. Maybe you could elevate the rear of the car to push the oil to the front.
Do you have any sharp bends in the cable? You might try some additional light lube into the cable housing. I have always been concerned about the amount of heat the angle drive and cable get sitting directly above the exhaust pipe.
Actually I have had a lot of problems with the 90 degree drives. There are two types. One that is simply a short piece of cable within the housing and the second that has actual gears. I went through two of the cable types. But I got my drives off of junked cars when I found the trannies.
Charley
M
mastaphixa
Bronze
Charley
Where did you source the gear type 90 drive? I share your concern about the heat.
charleyf
Off of a junked Toyota. A number of years ago. It is still working. I went through the whole inventory at a PICK & PULL. Crawling under each suspect Toyota. Sorry I can not be any more specific.
Charley
mctriumph
Guys, once and for all , you do NOT need the angle drive at all. There is room for the cable to fit
between the frame rail and the floor. I have personally done this on all the cars after installing
my Eaglegate conversion.
The problem as described is lubrication /long cable syndrome. All my new cables get lubed before
they are shipped .
Mad dog
bammons
I ran my cable over the transmission and did not use the 90* drive but since I posted I saw that my cable end at the transmission was shredded and found a "kink" that probably caused the shredding. How are the rest of you routing the cable? Bruce
M
mastaphixa
Bronze
MadDog, I understand your routing and will probably go that direction as I work on the passenger floor pan this winter. However, as stated in my original post, I have driven the existing cable set up with a battery drill and the speedo works beautifully leading me to wonder if there is a problem with the speedo drive gear in the gearbox. Believe me, I fully expected the 90 degree drive to be the culprit here and was surprised when it wasn't.
mctriumph
Bounce is often due to temperature /lube issues. Cold can cause old lube to make the cable
do strange things. This is also true of the escapement in the speedo its self. IMHO these old
technology gages have likely always had "issues", even from new.
Mad dog
M
mastaphixa
Bronze
To close the loop on this item, I replaced the speedo drive gear in the transmission. The gear had damage to the plastic gear teeth. Not sure how that happened but after I replaced the drive gear my speedo is pretty calm now. Reads a bit low, but at least it isn't waving at me in semi fore.
mctriumph
Ah Ha , unusual to see this gear fail but plastic is what it is.
My 3b is coming along, got the rear wings set back on permanently yesterday. the front wings
will be done by the end of the week which will complete the bodywork (happy happy joy joy)
Mad dog
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
PeterK General TR HVDA and Celica 5-speed hearbox Triumph 4
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
2wrench TR6 Hvda will not move into gear Triumph 7
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
2wrench TR6 Issue Installing HVDA transmission. Need your input. Triumph 6
2wrench TR6 Installing HVDA transmission. Triumph 8
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
PatGalvin TR2/3/3A TR3a HVDA gearbox cover fit issue Triumph 7
gubba Help anyone with HVDA Triumph 6
LastDeadLast Finally!! Test drive HVDA 5-speed install. Triumph 13
D Things you NEED to know before an HVDA Conversion Triumph 6
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
fad64b HVDA conversion Triumph 12
fad64b TR2/3/3A TR3 starters and flywheels HVDA Triumph 11
gubba Finally my HVDA is in ! Triumph 45
fad64b HVDA conversion Triumph 9
WidespreadPanic HVDA Toyota Tranny conversion: alternatives? Triumph 24
prb51 HVDA 5 speed tranny Triumph 18
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
BritBite Speedometer Right Angle Drive Austin Healey 5
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
