TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's
Scotsman
FYI Just installed a HVDA transmission conversion in my TR3A and have discovered that the W58 Toyota transmission is so close to the frame that the speedo cable has to make a radical 90* turn, possibly damaging it or effecting the functionality of the speedo. The cable also runs VERY close to the exhaust. Herman told me this occasionally happens and that there is a 90* speedometer cable adapter that can solve this problem. See below part number and picture. There is another type of adapter that is of cast aluminium but Herman said it is too large to work. If anyone has one they are willing to sell to me please let me know as I would like to install it before installing the transmission tunnel, carpet etc. I've had no luck on ebay, or local wrecking yards. Richard
90* Toyota speedometer cable adapter that attaches to a Toyota 5 W58 transmission. Toyota part number 43770-22120. Picture and possible vehicles it might come from below
Potential donor-cars:
01/1986-07/1988 TOYOTA SUPRA MA70
08/1988-04/1993 TOYOTA SUPRA MA70
08/1983-07/1988 TOYOTA VAN YR2*,3*
08/1988-12/1989 TOYOTA VAN YR2*,3*
08/1982-12/1987 TOYOTA TERCEL AL2*
08/1984-07/1988 TOYOTA CRESSIDA MX7*
Here's an image of the part:
Gliderman8
When I did my conversion on my TR6 with the W58 tranny, I needed to get a speedometer ratio adapter so the speedo would be correct. As I remember, it was a 90 degree adapter that I used.
It looked like the one below...
Geo Hahn
Use this info at your own risk:
A Google-ramble found this on a Kiwi forum:
https://oldschool.co.nz/2011/forum/index.php?/topic/39256-wtb-toyota-hiluxhiace-speedo-angle-drive/
Suggests you might look at p/n 83770-22100 or 83770-30070.
Just to see what would happen, I plugged those into a Toyota parts site and got:
https://www.toyotapartszone.com/oem/toyota~adapter~assy~speedometer~cable~83770-22100.html
https://www.toyotapartszone.com/oem/toyota~adapter~assy~speedometer~cable~83770-30070.html
Looks promising. Among the images on Google were these:
url
May work, but perhaps with the additional parts number your local Toyota dealer might have something you could examine.
charleyf
When I was doing my conversions I was able to find two different types of 90 degree adapters on Toyotas at the Pick and Pull site where we got our trannys. One was as shown with a cable inside it. It eventually broke ,I think because the speedo froze. The other type is more of a compact 90 degree type with a gear inside. I say this because there may be additional vehicles in the junk yard with potential donor 90's.
Charley
PeterK
I used a Toyota adapter on both my HVDAs, one W58 came with the adapter attached, one I purchased from Toyota for about $75. I also added ThermoTec heat shield which wraps around the 2 feet or so that's close to the exhaust on the 3A.
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
2wrench TR6 Issue Installing HVDA transmission. Need your input. Triumph 6
2wrench TR6 Installing HVDA transmission. Triumph 8
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR2/3/3A HVDA Speedometer Drive Triumph 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
PeterK General TR HVDA and Celica 5-speed hearbox Triumph 4
2wrench TR6 Hvda will not move into gear Triumph 7
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
PatGalvin TR2/3/3A TR3a HVDA gearbox cover fit issue Triumph 7
gubba Help anyone with HVDA Triumph 6
LastDeadLast Finally!! Test drive HVDA 5-speed install. Triumph 13
D Things you NEED to know before an HVDA Conversion Triumph 6
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
fad64b HVDA conversion Triumph 12
fad64b TR2/3/3A TR3 starters and flywheels HVDA Triumph 11
gubba Finally my HVDA is in ! Triumph 45
fad64b HVDA conversion Triumph 9
WidespreadPanic HVDA Toyota Tranny conversion: alternatives? Triumph 24
prb51 HVDA 5 speed tranny Triumph 18
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
