HVDA conversion
kodanja
How cool is that !!!!!!
congrats! enjoy!
Jerry
Hey,
What year Supra did that tranny come out of? I have yet to see the metal plate in the middle of the tranny on any that I have seen at the recycle yards. I found one last weekend that was out of a 1984 Supra. I could not find the milege of the doner call. Worries me that the thing might not last as long as I would like.
Jerry
TR3A Still original so far
BN4 with Toyota
BJ8 soon to have Toyota
Murray
Member
Hi:
I just finished my HVDA conversion this past Saturday. I used a 1983 Supra transmission that I took to a transmission shop to have it torn apart and checked. It didn't need anything but I had all new seals put in. There is a guy that has 6 or 7 Supra transmissions in Beloit, WI. He specializes in taking Supras apart and selling parts. I paid $200. for mine.
Frank, I didn't see a pedal stop in your pictures. Just wondering if you did that. I am in the Chicago area where it is snowing again. I am leaving for Florida tomorrow and will be stopping in Lakeland on Friday to see a friend. Small world.
Murray
PeterK
Looks good Frank (just like my 3A). One thing I noticed is that with the 3A, the shifter sits short. Mine too.
The steel plate 5-speeds were used in Toyota 2wd pick-up trucks. The Supras have an aluminum plate.
For my speedo, I had to use a right angle to get the cable away from the exhaust.
TexasKnucklehead
Looks great Frank. I also have the steel banded transmission. Did you have the flywheel redrilled for the TR6 pressure plate? Did you install his hydrolic throw out bearing as well?
martx-5
Nice Frank. I've got the HVDA kit that's going in on the restoration. The engine is just about done, so I'll be bolting up the trans pretty soon now.
I bought a resurfaced TR4A flywheel off of ebay for $40. I could've machined my old flywheel at work to accept the diaphragm pressure plate, but I also wanted the later style, bolt-on ring gear.
bobh
According to this link the steel plate was also used on later Supras.
https://www.answers.com/topic/toyota-w-transmission
"Toyota lists a change from an alloy sandwich plate to a steel sandwich plate around 1989. The steel sandwich plate has some minor internal differences, and it is believed to be slightly stronger (some wider bearings, some wider gears, slightly different gear selection mechanism etc). In theory the all alloy version of the W58 should be the exact same strength as any other all alloy W-Series transmission. The steel plate version is considered much harder to find and worth approximately three to five times as much as an all alloy version."
I bought a 1989 W58 from a supra that has the steel band. Now I'm building the courage to tell my wife I need to buy the HVDA kit.
BOBH
fad64b
fad64b
To answer the questions.
Yes I did use a pedal stop, I have less than an inch of travel of the master cylinder piston.
The shifter does seem to sit lower, but it sure is smooth.
Had my flywheel drilled and taped for the TR6 pressure plate but had a lot of trouble getting it balanced. The hole in the center of the flywheel is about 7/8". The machine shops need a minimum of 1 1/8 to set it on the arbor used for balancing.
Yes I used the new throw out bearing setup
PeterK
I have a steel plate W55? from a truck (in my 4A project) as well as a Supra W58 in the 3A (and a spare Supra for that matter).
My steel banded is from a truck, has taller 1-2 and according to the charts has less OD. I don't know how to find out what ratios they actually are but rely on the charts too.
Very smooth and with the short shifter, it's great for speed shifts.
Here's visual comparison bewteen the two. Celica Supra is top one, truck on bottom.
PeterK
One more.
Frank, notice the curved right angle adapter screwed onto the tranny. I covered the cable with thermo-tec heat shield to protect it from the exhaust pipe.
Also shown is the HVDA supplied cable holder-bracket just behind the starter buldge.
gsalt57tr3
I am not worried about how long my HVDA will last.
Within weeks of spending about 2 grand to rebuild my original transmission, yes another thrust washer disintegrated. Rather than rebuild it again, I decided to go with the Toyota. There are literally thousands of them available for less than $400 apiece.
I love driving down the freeway at 70 MPH turning only 2800 RPM.
martx-5
It's easy enough to figure out the ratios yourself. You may need a helper to count revolutions. Mark both the input shaft and output with a magic marker. I maked on one of the splines. Put the box in neutral and align both marks at 12:00. Put it in the gear you want to check. Turn the input shaft a number of times...10X is convenient. While you're doing that, have you buddy count the number of times plus any fractions that the output shaft turns. Simple math will give you the ratio. It will be as close as you can estimate on the output end. By comparing your figures that you counted in each gear with the chart, it will be very apparent which box you have. That's what I did to verify I actually had a W58 from a Celica.
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
D Things you NEED to know before an HVDA Conversion Triumph 6
fad64b HVDA conversion Triumph 9
WidespreadPanic HVDA Toyota Tranny conversion: alternatives? Triumph 24
M TR2/3/3A HVDA Speedometer Drive Triumph 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
PeterK General TR HVDA and Celica 5-speed hearbox Triumph 4
2wrench TR6 Hvda will not move into gear Triumph 7
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
2wrench TR6 Issue Installing HVDA transmission. Need your input. Triumph 6
2wrench TR6 Installing HVDA transmission. Triumph 8
PatGalvin TR2/3/3A TR3a HVDA gearbox cover fit issue Triumph 7
gubba Help anyone with HVDA Triumph 6
LastDeadLast Finally!! Test drive HVDA 5-speed install. Triumph 13
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
fad64b TR2/3/3A TR3 starters and flywheels HVDA Triumph 11
gubba Finally my HVDA is in ! Triumph 45
prb51 HVDA 5 speed tranny Triumph 18
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
AndreL TR6 Conversion to electric fuel pump Triumph 14
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
zoohow TR6 Carburetor Conversion kit Triumph 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
R Smitty Toyota Conversion Angle Drive Austin Healey 16
P Positive to Negative Conversion Austin Healey 1
P Pos to Neg Conversion Austin Healey 1
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
D transmission conversion Other British Cars 1
W TR2/3/3A Wire Wheel Conversion Triumph 5
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
petnatcar Breather Hose Conversion Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye disk brake conversion Spridgets 10
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
Walter74 Throttle Cable Conversion Austin Healey 6
PAUL161 T-Series Dynamator Alternator conversion. MG 23
M Dynamo to "Dynamator" Conversion Austin Healey 2
